poor running 351. help!
Old Jul 22, 2001 | 11:46 PM
red_rocket's Avatar
red_rocket
i just converted my 89' f-150over from a 302 efi, to a carbed 351. the 351 was from a 79 cougar with 60,xxx on it. I pulled apart the engine and put in all new gaskets and seals. Also a new roller timming chain (strait up) The intake and carb were from a 86 e-150 with a 351 h.o. I also added headman headers. I put in the engine and fired it up. It started hard and ran rather poor so i rebuild the carb. Once i installed the the rebuild carb and got all the vaccume hooked up right. it ran realy good, but could of been a little better, so i tried ajusting the floats(bad idea, first time for everything) I got them set so the fuel is just bellow the sight plugs, and it ran terribble! now no matter what i do it starts hard, wont idle, and is flooding out. after you open it up though it runs decent. but at lower rpms(wont idle) it realy runs rough. any suggestions??
Jared for tower, mn
1989 f-150 4x4 351 h.o.(formaly 302 efi)600 holley, 2" snowplow springs,3" blocks,3.50 gears(4.56's soon) 4 speed 9" with spool, 34" swampers
1989 lincoln lsc 5.0 h.o. aod stage2 shift, 2500 stall, 3.27's
1970 fj-40 all stock, 33x12.5 goodyears
1976 cougar xr7 1970 429, performer intake& cam, 750 carb (400h.p.)
Old Jul 30, 2001 | 12:34 PM
southernman1172's Avatar
southernman1172
[QUOTE] i just converted my 89' f-150over from a 302 efi, to a carbed 351.
There is the key right there. FI vehicles run on higher fuel pressures than carburated. Approx 30lbs of fuel pressure on the FI and maybe 6 on the carb. Get an inline fuel pressure regulator and a gauge and install it in front of the carburator and turn the pressure down some. The fuel, right now, is being forced into the carburater whether it wants it or not......
Chris
84 F-150 4x4 351W NP435
Old Jul 30, 2001 | 12:48 PM
southernman1172
mfewtrail
Dec 10, 2016 03:38 PM
89f150beast
22
Jan 28, 2016 07:12 PM
89302
Nov 14, 2015 01:48 AM
evin
Apr 16, 2004 08:43 PM
bruce r
Feb 1, 2001 09:33 AM
