engine trouble light when fuel is low
Old Apr 30, 2008 | 08:02 PM
meb9796's Avatar
meb9796
My brother has a 96 ford ranger, standard, 2wd, with 200,000 miles on it. His trouble light has been coming on for the past few months, but will go out when he fills is up with gas. When his tank gets down to around 1/4 tank it goes back on. He hasn't taken it to autozone to get the codes checked, so figured I'd check here to see if you guys have seen this before.
Old Apr 30, 2008 | 09:39 PM
pawpaw's Avatar
pawpaw
Kinda sounds like he may have confused the "Check Gauge" light, with a trouble light.
If he's down to 1/4 tank or lower & parked on a slope, the low fuel level in the tank, may be causing the "Check Gauge" light to come on, if his ride is so equipped.
Old May 1, 2008 | 07:41 PM
meb9796's Avatar
meb9796
nope, checked it myself
and saw both the check engine and the check gauge light on at the same time.
Old May 2, 2008 | 10:14 AM
77300i6's Avatar
77300i6
IIRC, the check engine light will come on if the computer does not think the fuel level is changing over a given amount of miles. The problem may lie here.
Old May 2, 2008 | 08:37 PM
Rockledge's Avatar
Rockledge
Could also be an EVAP issue, but why guess? Many autoparts stores will pull the codes for free.
