Sponsored by: Real Truck
1999 front rotors
Old Apr 30, 2008 | 07:23 PM
FishPOET's Avatar
FishPOET
1999 front rotors
I have a 1999 F250 V10 4x4. I need to replace a front rotor and I am having trouble finding one. The local shops have sent over 3 different rotors and all were wrong. I sent the old rotor over to CarQuest and none of the ones listed on their computer match the old rotor. Any suggestions?
Old May 1, 2008 | 07:09 AM
F350-6's Avatar
F350-6
Sorry, but this should be a simple straight forward deal. I've had rotors replaced on a 99 250 and never had any troubles.
Old May 1, 2008 | 07:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Never had any trouble? You've been lucky, or had them replaced by a dealer, or you don't have 4WD.
There are 5 different front rotors listed for 1999 F250 4WD's = FIVE!
It depends on the front axle stamping number, the GVW (over/under 8500 lbs), production date (before/after 3/22/99), axle ratio.
FISHPOET = the front rotors for 4WD trucks are listed in the front driving axle section...I need the front AXLE code TAG number & the production date to give you the correct Ford part number.
Front AXLE code TAG number, without it, I can't help...there are FOUR front axle parts lists (Section 30: #182 / #189 / #191 / #192)
If the Ford part number is known, it can be cross referenced to the aftermarket rotor part number.
Old May 1, 2008 | 07:50 AM
F350-6's Avatar
F350-6
Never had any trouble? You've been lucky, or you don't have 4WD.
I wasn't lucky. It was a 2wd. Now the problem makes more sense. Glad to see you're on top of things as usual Bill.
Old May 1, 2008 | 07:58 AM
NumberDummy
I didn't mean to be so sarcastic (sorry)...but looking up front brake parts for 4WD's is a genuine PITA.
On some models (like this one), it's almost impossible if one doesn't have that ^#@*& TAG number!
Old May 1, 2008 | 08:02 AM
F350-6's Avatar
F350-6
No you weren't sarcastic at all. I had no idea Ford had so many options on the 4wd models. For me it was simply walk in, give me 2 rotors and walk out.
That's why I'm glad we have people like you here who know better. Thanks.
Old May 1, 2008 | 10:32 AM
NumberDummy
Mi amigo, you have no idea...this is typical of Ford...if you think this is bad, just look in the parts catalog for 1973/79...there are over 100 parts lists for 4WD front axle parts.
Most ppl when they came to parts counters didn't have the Axle code, and it was a PITA, because all one could do, is compare one specific part number in one parts list with one in another.
1980 and later: emissions parts and fuel related parts can only be found in the Calibration Code (CC) Charts.
ONE specific yr, one specific model with one specific engine size, might have 30 different CC parts lists!
Overall, there are 800 CC parts lists for 1980/89's alone.
Cars? Don't even ask...they're worse!
If ppl think looking up part numbers is EZ, they have another think coming!
Old May 1, 2008 | 08:33 PM
miker67's Avatar
miker67
Yeah, those early 99 rotors are a pita. There IS a way to put the newer style rotors on, but you have to swap calipers too. It has been documented by a forum member somewhere, but I will have to dig around for the part numbers.
Old May 1, 2008 | 08:50 PM
FishPOET's Avatar
FishPOET
Thanks for the info Bill. I took the info from your post and CarQuest finally found the right rotors listed in their old catalog. Part #54063.
Old May 1, 2008 | 09:09 PM
99f350sd's Avatar
99f350sd
I think if you change the bearing to a newer one later than 3 99 and anewer rotor later than 3 99 you will be fine..
Dick
Old May 2, 2008 | 12:00 AM
Zip's Avatar
Zip
The early 99 seems to be the problem child. Nothing seems easy with them. So far for me. Track bar, blower motor and ubolts. Can't wait to do the brakes.
Old May 2, 2008 | 06:28 AM
99f350sd's Avatar
99f350sd
Mine's a 3/3/98. Doesn't get much earlier. I went to the newer track rod.
Old May 2, 2008 | 09:14 AM
SBastow's Avatar
SBastow
9/98 here. Geting ready to replace front rotors. Can't wait to go to NAPA and figure what ones I need. What a PITA! Where do I locate the axle code. Is there any other info I need to tell the parts guy to ensure I get what I need. Thanks
Old May 3, 2008 | 06:06 AM
Zip's Avatar
Zip
I went to the larger track bar as well when I put in my leveling kit.
Old May 3, 2008 | 06:41 AM
NumberDummy
Parts catalog sez:
Under the right hand lower suspension arm on a yellow piece of mylar.
Post it here...I'll give you the Ford part number for the rotor, and anything else you need (like seals).
