550hp 460
Old Apr 30, 2008 | 06:39 PM
ckcn10's Avatar
ckcn10
550hp 460
Hi, im looking to build a 460 for my 59 f100. I want it to be around 550hp but still have good low end, as it is a truck, is this doable? Also, what kind of heads and intakes are good to look at? would the factory highcompression, pre smog heads do good?
Old May 1, 2008 | 11:11 AM
mcdonaldm's Avatar
mcdonaldm
very easy to get your goals.
stick with dual plane intake for good low end torque numbers. the Weinend (?)Stealth Intake is probably the best one out there for this application.
stick to a 260 duration cam with around .5" lift, preferably a dual pattern intake with more duration on the exhaust if using stock heads.
don't really need the early heads if rebuilding. the later D3VE heads can be made to flow as good as the early heads, easier and cheaper to find and larger chambers gives you more choices with pistons to maintian 9 - 9.5: compression ratio so you can still use pump gas (although it will be hi-test). the only down side to d3ve heads, they should be converted to screw in rockers and adjustable drivetrain where as the early heads already have the screw in rockers.
either head needs a good port job on the exhaust and conversion to at least 2.19 intakes to get up around the 550hp range. nothing major that a competent machine shop can't ahndle (or you can do the port job yourself with guidance from reincarnation-automotive.com website, just have to pay the $25 registration fee)
with that being said, with the money invested in upgrading stock heads (larger valves, porting, studs, springs, rockers, etc) you are getting pretty close to the cost of aftermarket heads like the Edlebrocks or TFS street heads. they will blow away the stock heads in most depatments and will allow you to upgrade in the future (because once you have 550hp, you will want 600hp, then 650, then 700, etc)
go to 460ford.com for lots of info on the 385 series engine and lots of good build info in the archives.
550hp is very easy to obtain, just need to select the right parts and do the right modifications to your parts.
rgds
mike
Old May 1, 2008 | 04:36 PM
JBradley500's Avatar
JBradley500
you can get crate engines from carsbycarl.com
all he does is big block fords.
fordatic
Ford Truck Parts for Sale
Sep 18, 2016 12:33 PM
WillMcCabe
6.2L V8
Sep 13, 2016 10:48 PM
itsabullitt
Kansas Chapter
Mar 6, 2016 02:37 PM
1970Ford460
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Oct 18, 2015 12:14 AM
j250hd
Feb 1, 2012 07:04 PM
