Sponsored by: Real Truck
Shock Bolt Question
Old Apr 30, 2008 | 07:01 AM
tincup64's Avatar
tincup64
Shock Bolt Question
replacing my 104k mile shocks on my 99 f250 with bilstiens. the shock bolts are worn, a little concave - not bent. dealer wants alot of money just for new bolts. can't get 12mm at local hardware stores on grade 5 or 8 ... just the standard grade, whatever the 8.8 stands for.
question is, are these bolts special in any way? should i go with:
a - the original worn bolt
b - the standard grade hardware store bolt
c - the oem dealer bolt
thanks - tin
Old Apr 30, 2008 | 08:31 AM
SBastow's Avatar
SBastow
I've used the standard hardware store bolt in the past no problems.
Old Apr 30, 2008 | 11:09 AM
Monster-4's Avatar
Monster-4
The bolts should have been 10.9 which is a higher grade then 8.8. That may be why they are bent.
I know when I replaced my front shocks I managed to twisted one off (it was rusted and not coming out any other way). I replaced it with a factory one but I did go to the hardware store (True Value) before hand and found the proper grade, lenght and size just in case. The factory bolts where both stamped with a 10.9 grade.
Old Apr 30, 2008 | 11:18 AM
RDJ184's Avatar
RDJ184
it will work until you get a higher grade bolt
Old Apr 30, 2008 | 01:30 PM
cartmanea's Avatar
cartmanea
I would just use the worn one until you get a replacement of the correct grade.
Old Apr 30, 2008 | 01:33 PM
RDJ184's Avatar
RDJ184
if you replace it quick our the bent bolt might work the bushing
Old Apr 30, 2008 | 01:44 PM
cartmanea's Avatar
cartmanea
It was worn, not bent. If it is tightened properly this won't be a problem.
Old Apr 30, 2008 | 01:49 PM
RDJ184's Avatar
RDJ184
my bad
Monster-4's Avatar
Monster-4
Oops I read it totally opposite. Thought he said it was bent. My bad. Still think you need the proper replacment grade.
EDIT: RDJ184 - stop reading my mind!
Old Apr 30, 2008 | 02:22 PM
bpounds's Avatar
bpounds
You might check with an FTE sponsor to get a fair price on those bolts.
For example:
Direct Ford Parts Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
Bill
