Quick Gear Question
Old Apr 30, 2008 | 02:03 AM
bedmondo's Avatar
bedmondo
Quick Gear Question
Hey all,
I have a 3.55 rear with an AOD Transmission and 32 inch tires.
I spin really low rpms on the freeway, like 2,000 at 73 or something like that.
I was wondering how much of a gain I would see by switching over to 4.11 gears? I have put some performance parts on my engine but I can only see a difference in the higher rpms, it still is a dog. Would I really pick up some speed with the 4.11's?
Also, I do almost all in-town driving, 4.11's would help my gas mileage, right?
Is it worth it to try and find one of these axles?
Thank you!
Old Apr 30, 2008 | 11:52 AM
1980FORD's Avatar
1980FORD
I would say that you would notice the difference in acceleration and in town it would probably help you get into OD quicker but on the highway it will not help your gas mileage. Of course I don't think it will hurt it that much either. Check out the tire size/gear ratio/rpm table to see what you would be turning at speed. I think there is a good one at Novak conversion website or check in the offroad forum. They have several listed there.
Old Apr 30, 2008 | 12:38 PM
Kemicalburns's Avatar
Kemicalburns
your od gear is actually higher then mine with the e4od. i have 35's, 4.88's and in OD going 65mph my rpms are 2200 which for a 5.8 is at the bottem end of the power range so for you 4.10s would probably be just right.
Old Apr 30, 2008 | 03:28 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
It would help to know what engine size you have.
If you do a lot of in-town driving, leaving the AOD in Drive instead of O.D. will help.
Can't say much until I know what engine.
4.9L you are just about right with the RPMs
5.0L you need a lot of help, and definately a better gear ratio wouldn't hurt.
etc...
Old Apr 30, 2008 | 05:46 PM
bedmondo's Avatar
bedmondo
sorry! it's a 5.0
and at 65 i'm well under 2k rpms, i like to try and drive around 70-75 so the engine is closer to the powerband...doesn't slip out of OD as easily.
but like i said, most of my driving averages under 30 mph.
Old May 1, 2008 | 09:52 AM
Sycostang67's Avatar
Sycostang67
My city mileage improved going from 3:55 to 4:10.
Old May 1, 2008 | 06:21 PM
bedmondo's Avatar
bedmondo
how about your accelleration??
Old May 1, 2008 | 08:15 PM
uncle.stosh's Avatar
uncle.stosh
Obviously a 4.10 is going to get you moving quicker so acceleration is going to improve also.
Especially in a 3 ton truck.
Old May 2, 2008 | 03:14 PM
bedmondo's Avatar
bedmondo
will the 8.8's from an econoline van fit the f-150's, or are they a different size??
looks like the econolines would be the easiest place to find me some 4.10's
thanks
Old May 2, 2008 | 04:46 PM
81-F-150-Explorer
The rear end off of an econoline should work fine for you. I would find myself a 9" or a Dana if I was you, cause it's a better rear end, in my opinion.
Old May 2, 2008 | 04:47 PM
81-F-150-Explorer
Double post
Old May 2, 2008 | 08:17 PM
bedmondo's Avatar
bedmondo
i read that with the 9 inch you need a different length driveshaft...i could take the driveshaft from the van...but only if it was long enough to be cut to size...correct?
Old May 2, 2008 | 08:20 PM
uncle.stosh
thanks
I'm not sure about F150's but they are NOT interchangeable on the F250's.
I thought they were, but when I measured them in the junk yard the Van's are wider at the spring perches by about 4 inches IIRC.
RUNVS
Jul 8, 2011 11:03 PM
pipman76
Jun 25, 2009 09:42 PM
dougg
May 29, 2005 09:44 PM
fordguy351w
1978 - 1996 Big Bronco
Dec 1, 2003 02:40 PM
79_ford_400_guy
Apr 2, 2002 06:22 PM
