9.75 rear axle
Old Apr 27, 2008 | 02:22 PM
rgadley's Avatar
rgadley
9.75 rear axle
The door code for the axle says "16", but the tag on the rear says "3L29". Does anyone know which code tells me what my axle actually is? I have an '03 Expedition. Thanks.
Old Apr 29, 2008 | 03:10 PM
04markIII's Avatar
04markIII
what exact info are you looking for? i can get whatever you need with the last 8 digits of the vin number.
Old Apr 29, 2008 | 04:29 PM
rgadley's Avatar
rgadley
My experience with ford would says it is a limited slip with a 3:29 ratio.I was told the 16 is 3:73. I would like to know if it is a limited slip and what ratio I have. The last 8 are 3LC32410.I hope this is what you need.Thank you for your help.
Old Apr 30, 2008 | 01:37 PM
04markIII's Avatar
04markIII
3.73 open diff because you have traction control and rsc.
Old May 21, 2008 | 08:10 PM
PaulC's Avatar
PaulC
If the first digit in the two-digit code is a number, the differential is not limited-slip.
Old May 24, 2008 | 02:17 AM
Gdog89's Avatar
Gdog89
Axle Code
As a newbie to the list and this being my first post I'm not sure how to post a link but I have been researching Expy's for about 2 years and PaulC was correct. All Expy axle codes that are 16, 17, or 19 are non limited slip. H6, H7, H9 are all posi-traction (limited slip). I found the following in a PaulC post on a similar topic...
16 = 3.73 non-limited slip
17 = 3.31 non-limited slip
19 = 3.55 non-limited slip
H6 = 3.73 limited slip
H7 = 3.31 limited slip
H9 = 3.55 limited slip
Hope this helps.
jmlloar
Large Truck
Jun 6, 2015 07:51 AM
svemike
May 11, 2015 03:38 AM
Jeremy Kamutzki
Nov 9, 2013 08:45 AM
jowilker
Jan 28, 2000 03:52 PM
Dave Cooley
Jun 8, 1999 08:22 PM
