2001 Ford Excursion Limited
I just picked up a 2001 Ford Excursion Limited.
It has some issues, but I got it relatively cheap, so I won't cry. I'm willing to put whatever it needs to get it right.
I was hoping some of you could offer me some advice on the problems I found in it so far. Thanks in advance.
Issues:
1. Severe trembling when accelerating from just over 2,000 RPM to just about 4,000 RPM that goes away when I either accelerate hard to keep the RPM's up or just keep my foot on the pedal just enough to keep the speed up.
Had truck checked out at dealer who basically told me everything I already knew anyway ($200. for nothing). Only useful info is that the #2 & #4 cylinders are misfiring and that supposedly, the truck is only running on 8 cylinders. They said that if I continue to run it like this, I'll either damage the engine or the catalytic convertor.
The fuel injection system seems to have been replaced as it looks like it just came out of the box...shiny and new.
I suspect it's a fuel delivery or electronic system problem.
2. Short in electrical system leaves the passenger side running board lights on while truck is off and "Door Ajar" light on while truck is running and while all doors are closed. For now, I disconnect the battery when I park the truck for more than a 1/2 an hour.
Other than that, the only problem is a broken sway bar link...relatively easy to have replaced.
Ran CarFax on it, no flood/accident/salvage incidents.
Inteiror and exterior are pretty clean. It's a beautiful truck (pics coming soon).
I will have my personal mechanic (who's a Certified Mechanic with all the toys) take care of what the truck needs this coming weekend.
Questions:
1. Have any of you had similar problems with this trembling/running condition?
2. Are there any other issues I should look for while I have my mechanic under the hood?
Specifics:
Green with Tan Leather Interior
6.8 V-10
4X4
One more thing, it came without the floor condol, so I'm looking for one to put in it's place, possibly with a mini-fridge and/or DVDTV set up facing the rear seats.
Any suggestions for aftermarket companies?
Again, thanks for any help.
1. Wire Harness Replacement for fuel system
2. MAF cleaning
3. IAF replacement
4. Fuel filter
And now...
5. Coils On Plugs check.
I doubt the running board lights on is a short. Probably more than likely a dirty latch...
I never felt it misfire.
The dealer turned out to be a lieing sack of crap as he didn't do the bumper to bumper check I paid for.
So I feel he was lieing.
From what I read here, this problem is not uncommon with V10's so I'll try first what's suggested here working my way up from the least expesive fixes up to the major work.
Thanks.
