Sponsored by: Real Truck
Need Help !
Old Apr 26, 2008 | 11:34 PM
Broke's Avatar
Broke
Thumbs up Need Help !
I have a 2000 F250 7.3, We went to the bank this afternoon and when we came out the truck wouldn't start! After several trys to start while waiting for AAA It started right up, all the lights light up, the starter dosn't budge, Not really sure were what to do, I changed all the fuses, check all the wiring, Batteries, Any suggestions ?
Old Apr 27, 2008 | 08:54 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Did you do the CPS recall? If you didn't, bring your truck to your dealer and they will change it out for free. That is the first thing I would do. A bad CPS will kill your truck just like you turned the key off. If you don't know what a CPS is. click here Post what happens.
Old Apr 27, 2008 | 12:17 PM
F350-6's Avatar
F350-6
Welcome to FTE. So if I read your post correct you did get it started. Are you still having no start issues? If you turn the key all the way to the start position and the starter does not move at all the first 2 things I would check are any alarm or theft protection devices, and then the gear selector lever. If the truck thinks it's in gear it won't start. Shift it around some and hold it all the way up in park or shift into neutral to try and start it.
Unless it's a stick, which means check the clutch pedal position switch.
Old Apr 27, 2008 | 03:12 PM
Broke's Avatar
Broke
Thumbs up
Thank's guy's for your post ! I did play with the gear shifter a few time's, put it in nutrual and it still wouldn't start, This morning i went out to see if it would start and sure enough it fired right up !! And did this about 10 times as if nothing happend to it ! This is really weird, could that silliy little sensor be the cause for it all ?
Old Apr 27, 2008 | 03:25 PM
F350-6's Avatar
F350-6
The CPS can be temperamental. It can cause a stall, no start, miss, buck, jerk, or act completely fine all within a matter of minutes. A bad CPS will allow the starter to turn the motor all day long without starting.
I thought you said your starter would not turn. Did I read that wrong?
Old Apr 27, 2008 | 10:30 PM
Broke's Avatar
Broke
Thumbs up
I thought you said your starter would not turn. Did I read that wrong?[/quote]
Your right , When I was stranded the starter would not move like it had no power going to it, As I keeped playing with the ignigtion it finnaly started, Although I took the Batteries to do a volt check which turned out fine I'm wondering if it could be the cps or am I screwed with the starter ?
Old Apr 28, 2008 | 10:30 AM
rebelyell618's Avatar
rebelyell618
Originally Posted by F350-6
Welcome to FTE. If you turn the key all the way to the start position and the starter does not move at all the first 2 things I would check are any alarm or theft protection devices, and then the gear selector lever. If the truck thinks it's in gear it won't start. Shift it around some and hold it all the way up in park or shift into neutral to try and start it.
not to hyjack the tread from broke here but i have a question on what you said above.
Mine does this every now and then, when i turn the key to the start position it will act like i put i in accessory cause all the dash lights will come on but the engine wont turn over (starter wont even move). Then when i just slighty push the gear selector (automatic transmission) up while it is already in park, the engine will act like nothing happened and turn over.
so what would be causing that if you dont mind me askin. would it be a loose wire in there, a sensor, or just need a new shifter?
Old Apr 28, 2008 | 12:29 PM
Beerstalker's Avatar
Beerstalker
That would be either the nuetral safety switch, or your shift selector lever needs adjusted a little. Both are pretty easy fixes.
Old Apr 28, 2008 | 12:40 PM
F350-6's Avatar
F350-6
Beerstalker nailed it. The most common thing I've read about is just a loose lever. Look up underneath there and it seems like there are 2 torx head screws you can tighten up. (although leaving it alone makes for a nice anti-theft device)
Old Apr 28, 2008 | 02:17 PM
rebelyell618
thanks for the help..
as for the anti theft part.. that might have been what saved my truck from getting jacked a few months ago when i had the ignition punched out..
but thanks again...
Old Apr 29, 2008 | 12:17 AM
Broke's Avatar
Broke
Thumbs up
This is what I was trying to explain, I just got my truck back from ford for the cam sensor recall and they wanted to charge me $215 to hook it up !! Sorry that's why I'm BROKE
Thank's again to all for posting !
Thank's Beerstalker ! I'm doing that tommorrow!!
CLE-PRE
Jan 17, 2017 01:58 PM
thepicklesonice
Dec 19, 2016 02:28 PM
Ron94150
Aug 13, 2015 04:40 PM
exec land
Nov 3, 2012 06:23 PM
betsycam
Jul 28, 2004 09:46 PM
