anyway 95 psd, Banks ottomind chip, bouncy speedo,cruise works, no overdrive light, shifts hard 1 to 2 to 3 and when i put it in reverse some times it feels like it wants to take of but then it lets up and then it does it again and repeats until i put it in drive i think the tc is locking and unlocking. anyway need your help!
Does it happen with the Banks Ottomind removed?
Does it happen with the OD off?
A bouncy speedo may cause the trans to act-up.
Bouncy speedo might be your chip or the RABS on top the rear differential. Remove the RABS and clean the crud off it. It's magnetic and accumulates metal fuzz sending a weak signal to the PSOM (Programmable Speedometer Odometer Module). Check the wiring too, look for corrosion, bent pins ect.
Look into the RABS hole in the housing while turning the rear wheels. Is the tone ring, the thing with all the teeth on it, not the ring gear, going side to side or missing any teeth (rare).
