Need Help!
Old Apr 26, 2008 | 07:57 PM
Pud500's Avatar
Pud500
Need Help!
anyway 95 psd, Banks ottomind chip, bouncy speedo,cruise works, no overdrive light, shifts hard 1 to 2 to 3 and when i put it in reverse some times it feels like it wants to take of but then it lets up and then it does it again and repeats until i put it in drive i think the tc is locking and unlocking. anyway need your help!
Old Apr 27, 2008 | 06:32 AM
Cuda_jim's Avatar
Cuda_jim
Does it happen with the Banks Ottomind removed?
Does it happen with the OD off?
A bouncy speedo may cause the trans to act-up.
Bouncy speedo might be your chip or the RABS on top the rear differential. Remove the RABS and clean the crud off it. It's magnetic and accumulates metal fuzz sending a weak signal to the PSOM (Programmable Speedometer Odometer Module). Check the wiring too, look for corrosion, bent pins ect.
Look into the RABS hole in the housing while turning the rear wheels. Is the tone ring, the thing with all the teeth on it, not the ring gear, going side to side or missing any teeth (rare).
Marlinman10
Oct 30, 2012 07:50 PM
PLMCRZY
Aug 20, 2008 08:59 AM
rboeding
Aug 10, 2006 09:39 PM
87carbed
Garage & Workshop
24
Jun 22, 2005 03:42 AM
Fuelinjector06
Aug 9, 2004 09:33 PM
