whats your pyro temp?
Old Apr 26, 2008 | 03:55 PM
That_Guy's Avatar
That_Guy
At idle im running 4000, I think thats a bit high and when I started my truck up this morning it was at almost 2000 so im thinking i just need to adjust the needle on the gauge. At WOT I hit 1200 pretty quick and the truck still has more in it so thats another reason Im thinking It still needs to be adjusted.
How would I go about adjusting the needle if there even is a way to do it?
Old Apr 26, 2008 | 04:01 PM
ron's power stroke's Avatar
ron's power stroke
2000 and 4000
65 to 70 MPH i run 750 to 800..full wot run ill hit 1250 around 100 MPH
could be the probe is reading wrong...
Old Apr 26, 2008 | 04:04 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Darn Chris, 4,000 and 2,000, I think you mean 400 and 300*. It would be nice if we could set the gauge to what ever we wanted, but I don't think the pistons would like you for that. What kit do you have and where did you get it. Did you put it in the up-pipes or manifold?
Old Apr 26, 2008 | 04:10 PM
That_Guy's Avatar
That_Guy
I did mean 400 and 200 dunno why i hit another 0?? lol
but its reading 200 before I even have the truck running.
the probe is in the manifold, I didnt install it but I made sure it went in there. and the guy that did it used to own a cummins so he knew what I was talking about ( well i hope so). I got the kit from thorough bred desiel its a auto meter kit. I just thought that like most thermomoters they might not be calibrated so I just needed to do that.
Edit: just checked again, Its at 100 with no power to the truck and 200 when the key in in the ingntion waiting for the glow plug light to go off.
Old Apr 26, 2008 | 04:19 PM
miller_feed
Chris, these are what I have and they work great. Your gauge should not read 200* when your truck is not running. Clicky here. You don't want to take a chance with your EGTs.
Good luck.
Old Apr 26, 2008 | 04:25 PM
ron's power stroke
my autometer will jump up when i key on first thing in the AM..after start up it will drop and then climb....
Old Apr 26, 2008 | 04:26 PM
That_Guy's Avatar
That_Guy
Good luck.
Im thinkin the gauge wasnt calibrated right (reads 100 instead of 0) since it reads 100 with no power and never goes below that. Goin to call the thorough bred on mon and see what they say. I do like those those gauges Rick, but I couldnt beat the price on mine.
Old Apr 26, 2008 | 04:28 PM
That_Guy's Avatar
That_Guy
mine wont drop though. just jumps to 200 when it gets power and then climbs to 400 while still idling.
Old Apr 26, 2008 | 04:30 PM
miller_feed
Chris, you know the old saying, (you get what you pay for). But I do understand about the $ thing.
Old Apr 26, 2008 | 04:36 PM
That_Guy's Avatar
That_Guy
Yea I know, but I thought all autometers should be the same right? I paid 295 to my door since they were on sale, they came new in box with everything so guessing I just got a dud.
Old Apr 26, 2008 | 04:38 PM
miller_feed
They should make it right for you. Just give them a call.
Old Apr 26, 2008 | 04:40 PM
ron's power stroke
use a heat reading gun..(cant remember what its called) see what the manifold reads next to the probe and see if the gauge reads near the same..
Old Apr 26, 2008 | 04:51 PM
That_Guy's Avatar
That_Guy
yea I will on mon.
Thats a good idea, Ill have to see if my dads got one lying around...
Old Apr 26, 2008 | 05:18 PM
distortedcloud's Avatar
distortedcloud
Does it reset back to zero when put the key in, cause its suppose to reset to zero then go back to what the actual temp is. i`ll get a video later of what should happen.
Old Apr 26, 2008 | 05:30 PM
That_Guy's Avatar
That_Guy
It doesnt start at zero or go to zero the lowest it goes to is 100
