Best Wax?
Really easy to put on and wipe off, lasts about 2 weeks, and 2 washes
Also looking for a good wax, to get rid of the spider scratches on the black paint
Bruno
I use the Turtle Wax Ice on my truck and it works well. More of an in between wax and spray detailer (which they have). It's easy to apply and you can put it on in any heat and on any body panel. I use the spray detailer after washes so I don't have to chamois it. It's really easy to just airdry the truck, grab a microfiber cloth, and spray on and wax off. It takes 5 minutes for an incredibly spotless truck.
That's more of the "I have 2 hours to wax my truck" kinda wax. If you want something that will take all day, and show it, then get the Zaino. It costs an arm and a leg too for the whole kit. I think I got all my stuff for around 30 at Walmart.
-rockstate
-rockstate
Mothers makes a good product. I especially like their "Back to Black." Used that quite a bit on the Expy. I highly recommend it if you have some fading black trim.
-rockstate
To me, Zaino is much simpler than others. Get it on the trim, doesn't matter, comes right off. No white polish residue in the cracks and seams either. It literally lasts forever with amount you will use. And it holds up a long time. They have several newer products that simplify it. I've used the AIO and it seems to work just fine in one step. You really could get by with just that, though I would recommend Z-6 gloss enhancer to go with it. Later on, get some Z-2 and make it pop.
The one beef some people have Zaino is the way it refracts light. It almost appears to glow at times. I don't have any good pictures of that, but here is one of the hood of my car after a coat of Zaino Z2.
http://home.comcast.net/~01gtb/bullitt%205.jpg
A clay bar will remove tar and road grime, pollution, dried concrete, hard water spots, bird droppings, you name it, but will not remove orange peel, which is in the paint finish itself.
Run your hands over the paint, feel all those tiny bumps?
That's tiny drops of pollution, washing, polishing and waxing will not remove all of it.
Drive into the sunlight, see all those spots on the glass? That's not caused by sandblasting, it's more pollution.
Wash vehicle, use two clay bars, one for the paint, t'other for the glass.
You can buy a clay bar kit at any autoparts store for about $20.00.
The bar that comes in the Mothers kit is larger and easier to use than the two bars that come in the Meguairs kit, that are very small, and damn near useless.
Clay bars require lubricant, the qwik detail made by Mothers and/or Meguairs works on the paint, for a glass lubricant, I use Invisible Glass.
Clear coat paint = go EZ with the scratch remover, every time you use it, it takes off some of the clear coat.
Be very careful with the type of wax you use with clear coat paint, some waxes contain silicone...you do not want to use that type of wax on clear coat paint!
Silicone will strip off the clear coat. Do NOT spray silicone near a clear coat finish.
Antique furniture, gunstocks, any wood with an oiled or French Polished (shellac) finish = read the label of the furniture polish/duster stuff you're using.
Some contain silicone = do not use that crap on these types of wood finishes!
> > DO NOT USE A CLAY BAR ON HOT METAL, IT WILL LEAVE A CLAYEY RESIDUE. GETTING THAT RESIDUE OFF, IS A ROYAL PITA! < <
Great explanation!! Thank you i have a black truck and there are some minor scratches in it. I'll try your suggestion and see what happens. I used to send it out to a detailer but he closed up and moved out of state. Now I'm looking for one that I can trust.
