Update...
Old Apr 26, 2008 | 10:23 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by schlepprock379
Another question....Tonight...I was on the interstate running 70 mph, my egt's were staying right at 800 degrees. Does this sound about right?
Yep, you are on the money with your EGTs.
Old Apr 26, 2008 | 10:25 PM
schlepprock250's Avatar
schlepprock250
Right on..I just got my gauges installed and have never run gaugs before so I wasnt sure ...Thx
Schlepprock
Old Apr 26, 2008 | 10:31 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yes, the injectors get alot louder and cacklier when you switch programs. Even though youre not supposed to do it, change from stock to a performance program under light throttle, you can really hear it change. What it is doing is ramping the Injector Control Pressure up alot higher.
Old Apr 26, 2008 | 10:35 PM
That_Just_Happened's Avatar
That_Just_Happened
i can hear my injectors knocking in the 80 and 120 setting...that seems a little high on the egt...i have a 4" dp to a 5" rest of the exhaust and i run around 650 on flat going 70-75...i also have my sensor in the up pipe so that can account for the lower reading of the egt...
im sure others will chime in about those egt's
Old Apr 26, 2008 | 10:37 PM
schlepprock250
Cool...thats what I thought just want to be sure something bad wasn't happening..lol, yeah when I changed programs I wasn't on the throttle. I would let off and then change then get back on it.
Thx alot...Schlepprock
Old Apr 26, 2008 | 10:42 PM
schlepprock250
Ya know...if I recall...I might have been going up a SLIGHT grade.
Old Apr 26, 2008 | 10:44 PM
That_Just_Happened
those "slight" upgrades really affect the egt's...i don't try to watch the gauge constantly while driving but sometimes ill see it coming down from 750 after a small upgrade, so that'll do it.
Old Apr 26, 2008 | 11:01 PM
UP_There's Avatar
UP_There
mine will generally hover around 650 at highway speeds, but can ramp up to 850 easily with even half throttle.....won't go over 900 unless I really get on it. This is with probe installed in exhaust manifold....
Old Apr 26, 2008 | 11:04 PM
schlepprock250
Ok...Gotcha..I have my probe mounted in the uppipe just above the manifold connection.
rblaine9000
Aug 12, 2009 04:21 AM
Ponyboychris
18
May 31, 2008 12:57 AM
Futuresweets-10
Oct 13, 2007 11:29 AM
chesterstroker
19
Jan 27, 2007 11:53 AM
Dually02
Jun 6, 2006 08:22 AM
