Differential covers
Old Apr 25, 2008 | 09:12 PM
TxFordGuy's Avatar
TxFordGuy
Differential covers
I was wanting to put finned aluminum diff covers on my truck. Does anyone know if the new SD's have the same axel as ours. I was hoping it would bolt right up so i can go look in a junk yard for a wrecked one? Any thoughts? Also what weight are you guys running. I was going to go with royal purple 75-140.
Old Apr 25, 2008 | 09:31 PM
big poppa's Avatar
big poppa
I know in my trucks rear axle i got 75-140 weight gear oil. I seen in an earlier thread that royal purple already got the friction modifier in it. As for the diff cover i'll bump you back up.
Old Apr 25, 2008 | 11:24 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I run the Royal Purple 75W-140 and it has the friction modifier you need. I've got 4 extra bottles if you have trouble finding it locally.
As for a diff cover, look HERE for DieselManor's package. It's the diff cover used on the 08's and will fit any SRW back to 99 for sure
Old Apr 26, 2008 | 07:58 AM
bkcowboss's Avatar
bkcowboss
You are correct, the 08 SD cover fits our rear axles, it is an easy swap, you need fluid and you need some silicon gasket maker, I had to use a puddy knife to get the old gasket materiel off, and you have to get longer bolts cause the bolts for your old cover are to short. I got stainless bolts from lowes cause the bolts from ford are spendy. works like a champ
Old Apr 26, 2008 | 08:13 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I'm sure you know how to do this but here is the how to on changing the fluid. click on the this.
Old Apr 26, 2008 | 01:12 PM
TxFordGuy's Avatar
TxFordGuy
WOW, that diff cover is cheap. all the ones i kept find when googling were like $200+. Is the cover on the 08's aluminum or is it just finned? Cowboss, are you using one off of an 08?
Old Apr 26, 2008 | 01:44 PM
papadelogan
I went with the 08 diff cover on my 99, but since she's black and 'stock' bothers me, I had mine powdercoated (~$30)
If you order the diff cover through DieselManor (in the link I provided earlier) they will send you the cover with the proper bolts. You need to supply new fluid, some silicone gasket maker, the tools, & the time. It is aluminum as well, so in my book, it's by far the best deal going.
Old Apr 26, 2008 | 02:16 PM
CSIPSD's Avatar
CSIPSD
Its AL... and thick enough to drill and tap for a sender!
bobalonius
Apr 6, 2012 05:19 AM
SBastow
Mar 28, 2008 07:55 AM
stegmst
Jul 19, 2005 12:03 AM
TrimmellFord
Aftermarket Products
Oct 27, 2004 12:32 PM
mrblack
Aug 6, 2002 09:56 AM
