Sponsored by: Auxito
E-Brake Question
Old Apr 25, 2008 | 05:08 PM
Sethman33's Avatar
Sethman33
E-Brake Question
I have an 03 F150, and I put a 7 inch lift on it. When I go around turns, there is a clicking noise coming from the rear. That, and when I go to reverse after releasing the E Brake it won't back up. I have to pull forward a little and then it will go. Is it lifted too high, and will lowering it a little fix the problem?
Old Apr 26, 2008 | 03:57 PM
jimm66's Avatar
jimm66
I don't know about your lift, but the e-brake is a crappy little drum set up that doesn't last very long or work very well. I had mine replaced because it was all in pieces making a lot of noise. Even the new brake barely holds me on a boat ramp. The clicking noise could be your limited slip.
Old Apr 26, 2008 | 05:19 PM
Sethman33's Avatar
Sethman33
Hey,
Thanks for the Info. I guess if everyone knew that it is a 4.2L XL 4x2 that would help. Sorry bout that. I am pretty sure that it doesn't have limited slip in the rear. In fact, my truck does one wheel burnouts. Wouldn't that mean I am without LS?
Old Apr 26, 2008 | 07:37 PM
96f150's Avatar
96f150
I'm pretty sure the height of your lift has nothing to do with it. I would start by pulling the rotors off in back and see how the parking brake shoes look. The clicking may be the self adjusters in the system
Old Apr 26, 2008 | 09:19 PM
steve(ill)'s Avatar
steve(ill)
96F150 is right, look at the rear brakes.
Old Apr 26, 2008 | 11:36 PM
Sethman33's Avatar
Sethman33
I think you may be on to something. I may have stretched something out when installing the blocks. When I go around a corner it sounds like a ticking noise. I am wondering if I screwed up the adjustment some how by lifting it too high. From my understanding, the cables can get stretched. Am I correct on that? If that can happen, then is it possible that the E Brake is not disengaging fully? By the way... THANKS for the HELP. Much appreciated.
Old Apr 27, 2008 | 06:41 AM
96f150's Avatar
96f150
Did you put on a body lift or a suspension lift?
Old Apr 27, 2008 | 03:34 PM
Sethman33's Avatar
Sethman33
All suspension. Its a good 7 inches of lift. The Fabtech longtravel kit. 7.5 inches in the front and about 7 inches in the rear. And not 7 inch blocks but a combo of block and leaf pack. I am thinking I stretched the cable out. I did find a wonderful part to the lift kit that I didn't see when putting the rest of it on. It is a e brake cable relcation bracket. Its there to take the tension off the cable that IS CURRENTLY THERE. Thanks guys. I really appreciate the help. I am just an idiot.
Old Apr 27, 2008 | 03:47 PM
96f150's Avatar
96f150
Hey, thats what were here for.....to help out with these great trucks. Now lets see some pics posted of your lifted truck.
Old Apr 28, 2008 | 12:44 AM
Sethman33's Avatar
Sethman33
I will do that. I just have to get my camera out. Its not bad. I think that I am going to take out the custom racing seat setup, and find some nice 40 20 40 seats, or even some Lightning seats. I guess I am gettin old now and like the lift, but not the rest. My definition of cool has changed a bit now.
lilsmokey
Sep 25, 2012 09:16 PM
DavidAnderson
Apr 8, 2012 08:48 AM
CHOPPER0389
Dec 29, 2009 05:36 PM
78bigbronco
1997 - 2003 F150
Aug 24, 2005 06:28 PM
