Sponsored by: Real Truck
Question about DRW's
Old Apr 24, 2008 | 04:41 PM
FLYBOY07's Avatar
FLYBOY07
I have a 1995 Ford F-350 Psd CrewCab Dually. I need to get it into the shop and do some routine maintence and would like to put it on a lift.. My problem is the shop I have access to on base door clearence is about 95 1/2" wide the truck From fender to fender. So it doesn't look like it will clear the door. my question is How do I remove the fenders? It looks like they are bolted on but I'm also seeing welds. but the way it as if the Fender stops before the welds.. But I'm not exactly sure and wanted to check before I wasted mine and a couple of buddies time. or the other option is to drive a 160 miles one way to another base where I can pull right in with the mirrors and all. and with diesel sitting at $4.15 right now in the big country, it doesn't make a whole lot of sense if I don't have to. Thanks for the help guys
Vance
Old Apr 24, 2008 | 04:50 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Wish I could help you but my fenders are fiberglass.
Old Apr 24, 2008 | 05:02 PM
FLYBOY07's Avatar
FLYBOY07
So are mine.. but thanks anyways
Old Apr 24, 2008 | 08:21 PM
Spike Engineering's Avatar
Spike Engineering
Originally Posted by FLYBOY07
...my question is How do I remove the fenders?
Just drive fast enough into the shop.
Old Apr 24, 2008 | 08:50 PM
BareBones's Avatar
BareBones
Actually, I think there are only four main bolts holding the entire bed on. Remove the bed.
Old Apr 24, 2008 | 09:08 PM
highland61's Avatar
highland61
you have buddies help with routine maintenance?
seriously, just call jiffy lube
Old Apr 24, 2008 | 09:43 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I'm with bones, just pull the bed. If you have a couple of buddies there it shouldn't be a problem to lift, just some electrical connectors and the fuel fill line. But there are 8 bolts I think? T50 torx bits.
Old Apr 24, 2008 | 10:03 PM
aldridgec's Avatar
aldridgec
Yeah, but those t50's can be a pain to get out.
Old Apr 24, 2008 | 10:06 PM
CampSpringsJohn's Avatar
CampSpringsJohn
There should be an easier way to remove the fenders than removing the bed. Some car haulers remove the fenders and the outside rear duals to load them on their trucks. Any car haulers out there?
Old Apr 24, 2008 | 10:23 PM
1996pwrstrk's Avatar
1996pwrstrk
I have removed mine (a 1999 ) there are studs in the fiberglass part that go through the the bed side with nuts to secure them I don't imagine that a OBS would be that much different. Just get under the bed and reach up and feel around the outline of the fiberglass part and see if you find them.
Old Apr 24, 2008 | 11:30 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Then how are they welded?
Old Apr 25, 2008 | 12:25 AM
FLYBOY07's Avatar
FLYBOY07
LoL very funny.no actually I'm doing routine maintence and fixing a couple things that I've let go too long (thermosat, lights, tranny fluid change brakes etc etc... and I got something wrong with my left rear drum sounds like metal to metal contact. and since I don't know a whole lot about them I'll ask someone who does. don't be making of me it hurts my feelings
P.S. I wouldn't call Jiffy Lube if I was dying on my death bed. I just had to eat $300 For an Oil Cooler adapter because some dumbarse cracked it and not only that but had the oil filter gasket on backwards and the filter not on tight lost damn near over 10 quarts of oil. Never again will anyone be touching my truck but me unless that E40d decides to fail thats about the only thing I won't mess with.
Old Apr 25, 2008 | 12:32 AM
FLYBOY07's Avatar
FLYBOY07
cause I'm a dummy. i saw some welds going from the body. but it turns out just like they said It's just a couple of bolts running the edge of the fender.. but I'm actually considering removing the bed since I gotta put that exaust in a couple of weeks It sure as hell make everything easier. and thanks guys for the help Greatly appreciated
Old Apr 25, 2008 | 08:12 AM
BareBones's Avatar
BareBones
If you do remove the bed, I'll pass on a recommendation I read earlier on the forum. Get a brass hammer and beat the crap out out of each bed bolt maybe 3 or 4 strikes to break it free. Should come off easily after that, mine did.
Old Apr 25, 2008 | 08:34 AM
miller_feed
I am still wondering why you need to go through all that lifting and stuff to do maint on your truck. I do everything myself to my truck and never lifted it. But then again, if I had a lift, I guess I would use it.
