Why did my engine stall....
Old Apr 23, 2008 | 09:54 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Hello every one,
Well to day my dad and my I installed new rotors and went for a test drive to do the break in for the new pads and rotors. So we decide to have a little Fun and do a burnout. So we find a place put in 140 smoke hit the brake and bunch it the tires light up and it gets to 900 degerss and 20 pounds of boost and then Quite the engine died. And I am thinking thrown rod after I just read the story about the other FTE member that threw a rod but it started right back up. So my question is why did it do that,
Thanks
Nick
Old Apr 23, 2008 | 09:56 PM
clux's Avatar
clux
Did it quit while you were still on the throttle or when you let it idle down?
Old Apr 23, 2008 | 09:57 PM
megawatt00's Avatar
megawatt00
Could it be a CPS issue?
Old Apr 23, 2008 | 09:59 PM
weekendwarriorfsw32
Master of Strokes
When I was on the throttle
Old Apr 23, 2008 | 10:00 PM
weekendwarriorfsw32
Master of Strokes
I don't think so because we were screwing around earlier on 140 and nothing happened
Old Apr 23, 2008 | 10:03 PM
clux's Avatar
clux
How's your oil level?
Old Apr 23, 2008 | 10:04 PM
weekendwarriorfsw32
Master of Strokes
I will go check right now.
John311t's Avatar
John311t
Did it happen to shift during this, if so it probably ended up with too much air, and not enough power/fuel to keep it going. If you windowed the block you would know, it makes some funny noises when a rod is just flapping around.
Old Apr 23, 2008 | 10:17 PM
weekendwarriorfsw32
Master of Strokes
well the oil is full
Old Apr 23, 2008 | 10:18 PM
weekendwarriorfsw32
Master of Strokes
I don't rember I will go ask my dad now
Old Apr 23, 2008 | 10:25 PM
weekendwarriorfsw32
Master of Strokes
Yes it happened a few seconds after it shifted into second
Old Apr 23, 2008 | 10:28 PM
pullinair's Avatar
pullinair
torque converter was locked and stalled the engine becuase the vehicle was not moving when you lifted on the throttle. Only thing I can think of.
Old Apr 23, 2008 | 10:29 PM
John311t's Avatar
John311t
Too much air, not enough rpm's. Your good. My truck has done it also(at the track once, and on the roads whippin donuts). Rock on.
Old Apr 23, 2008 | 10:32 PM
weekendwarriorfsw32
Master of Strokes
Thank god thats what I wanted to hear thanks. Is there any way to stop this or is it just the nature of the beast
nick91l
Nov 2, 2012 06:25 PM
Nick_lebbad
Feb 24, 2012 05:09 PM
NickE
Apr 22, 2011 12:00 AM
bghnkinf250
44
Mar 19, 2010 01:41 PM
weekendwarriorfsw32
19
Apr 15, 2008 01:03 AM
