Changing U-joint's Suggestions
Old Apr 23, 2008 | 11:35 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
For years and about 100,000 miles I put up with a slight but very annoying driveline vibration. I would take it to a shop and between me and the mechanic we would pick a u-joint or 2 to replace. It would get a little bit better for a few thousand miles but would always come back. Did this 3 or 4 times until I bit the bullet and removed the entire shaft and took it to a driveshaft balancing service. Yes, it was a little bit out of balance, but the biggest problem were the cups in the yokes. A couple of them had worn to the point that they were causing premature u-joint failure, not to mention the vibration. Just a thought for everyone, I am sure the same could apply to the short shafts in 4 x 4 front axles.
Old Apr 23, 2008 | 11:50 AM
just another truck's Avatar
just another truck
Thanks for the heads up, looks like I thanked you already this week, and have to share the love, sorry, reps would have been sent.
Old Apr 23, 2008 | 12:04 PM
DieselCamper01's Avatar
DieselCamper01
I sent yyou some love Mark. Great tip
Old Apr 23, 2008 | 12:22 PM
dryfly's Avatar
dryfly
I agree Mark,I take mine to the local driveline shop when it needs u-joints.Not because I can't change them,they are easy enough.But I like the fact that it is balanced and inspected by a specialty shop.The cost was well worth it I think $160 for the front shaft with that pain in the ash c.v.type joint.
Old Apr 23, 2008 | 12:26 PM
brnab1's Avatar
brnab1
Thanks for the tip ..... I just went through this ill have 2 check those if i have a problem !!!
Old Apr 23, 2008 | 02:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Good post Mark. I was able to a fraction of a green box.
Old Apr 23, 2008 | 02:15 PM
eatfish's Avatar
eatfish
OK, I need an explination... What do you mean "cups in the yokes"? The u-joint caps?
Old Apr 23, 2008 | 02:52 PM
Markadeck's Avatar
Markadeck
No, the beds in which the cups of the u-joint rest in and are fastened with the band and bolts.
Old Apr 23, 2008 | 03:57 PM
eatfish's Avatar
eatfish
That is what I initially thought, but it is hard to imagine that there would be that much wear with no moving parts. Guess the steel is pretty soft and they are "egging out." Thanks for the heads up.
Old Apr 23, 2008 | 04:21 PM
rbaker6336's Avatar
rbaker6336
sometimes u-joint removal/install tecnque can result in a damaged driveshaft yoke
Old Apr 23, 2008 | 04:26 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
hence the phrase... "ham fisted"
Old Apr 23, 2008 | 05:57 PM
farmdad's Avatar
farmdad
Does Ford use the "injected plastic" to hold the u-joint caps in place? I ran into this on a '98 Jimmy. What a rinky dink way to build a vehicle. Had to use a press to break them loose. I hadn't run into this on any Ford that I have worked on.
Old Apr 23, 2008 | 07:29 PM
megawatt00's Avatar
megawatt00
Good tip Mark. Thank you. i have to pull my front drive shaft, i get a vibration in 4 wheel.
ilateapex
16
Dec 29, 2012 02:36 PM
blackkawi400
Jan 8, 2011 10:52 AM
Bob's attic
Jul 28, 1999 09:06 AM
