1979 f350
Old Apr 23, 2008 | 12:35 AM
capnmorgking's Avatar
capnmorgking
Question 1979 f350
how much can it tow? has a 429 (rated 250 hp @ 4300 & 371 ft lbs tq @ 2430) c-6 trans (stainless gears) dana 70 with 3.73 ratio.no lift stock hd tires. it is 2wd.
Old Apr 23, 2008 | 12:58 AM
RCrawler's Avatar
RCrawler
I think the factory rating was 10K lbs with 4.10 gears
Jason
Old Apr 23, 2008 | 10:04 AM
capnmorgking
10k lbs is what a chevy 1500 is rated at towing, i dont want ratings i just want to know if it can tow 15000 lbs? and yes my trailer does have brakes.
Old Apr 23, 2008 | 10:15 AM
RCrawler's Avatar
RCrawler
It will tow 15K, but not legally. I've pulled 100K lbs with my diesel, but I wouldn't want to try to stop it.
Jason
Old Apr 23, 2008 | 11:02 AM
zoomeroo's Avatar
zoomeroo
Towing heavy
You will be entering a really expensive fine area towing something over 10,000 lbs unless you have a truck that is set up with what is called Combination Weight.
In short, you have to liscense your truck to handle the entire load of trailer and truck. The weight cops love to get people in this area. It is an easy pinch.
Does what you want to tow look like 15,000 lbs? Or is is a travel trailer?
As far as will it do it? I would say it depends more on the driver then it does the truck. The human behind the wheel can make or break any truck.
I tow 13,000lbs plus behind a 3/4 ton 250 miles 12 times a year. 10 times a year it is through mountainous terrain and pulling a very steep 3 mile mountain. i take it easy and pull the mountain in the cooler hours of the day. And i am doing this with a NOT FORD. I am building an F350 to do the same job though and can't wait till it is done.
Old Apr 23, 2008 | 03:43 PM
capnmorgking
its a 4500lb trailer and a 3800lb truck and 3600lb car, 2 axle with 12 drum brakes.
Old Apr 23, 2008 | 05:34 PM
Mil1ion's Avatar
Mil1ion
I would be more concerned with being able to stop...... than pulling
What 429 is this ...from an F600 ?
My 429 with 385 HP pulls and stops when I pull my fully loaded trailer.
Total weight 11,000 lbs
Old Apr 24, 2008 | 01:03 AM
capnmorgking
my 429 is out of a ford torino i believe. why would u be concerned about my stopping power? it has 12.56 in front disks and 14 inch rear drums, 4 12in electric trailer drums.is that not enough?
Old Apr 24, 2008 | 04:18 PM
Mil1ion's Avatar
Mil1ion
Whoops ...I just noticed F350 not F250
Depends on speed and terrain.
You should be fine
Old Apr 25, 2008 | 01:29 AM
capnmorgking
thanks everyone.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
