Slight miss/vibration...
Hello, ive been searching but really need to know if what i think it might be applys to my situation. First off i got a 01 F350 7.3L stock except for kwik filter mod if that matters. I got an oil change a couple days ago and after i noticed a slight miss, or vibration at idle. Idle seems kinda funny too. Guy in my shop did the oil change, checked over everything oil is good, connections seem fine. I thought maybe it was air in the system or something, but its still doing it.
The other day i started it up, was fine... go to drive through and it started doing it, then took off and sitting at a stop light it was fine..... Seems to do it intermittently. Got the test done with a ford scanner at work, it passed and threw a code P0476 but my CEL is not on. I have cleaned the EBPV tube and sensor a couple months ago. The vibration is not bad but i notice its there and its not normal, also it seems performance is lacking a little and it sounds kinda sick. Was thinking it was the UVC harnesses coming loose but which one do i check? Both? Any help would be appreciated, i gotta tow my toyhauler this weekend would like it fixed before then. Thank you.
if you intermittent miss seems like that of a fouled plug on a gasser, you are not alone. Quite a few people here (including myself) have been plagued by this. Have you changed your fuel filter lately? The only time I would notice a lack in performance was when the filter was getting dirty (reason i did the hutch).
I must say, though, since running some 2 cycle it has completely disappeared on mine. Not even DK got rid of it. I am not saying the 2 cycle got rid of it, but mine has not done it since.
I put 15w40 motocraft in it. I got some crc diesel fuel injector cleaner additive, added a bit and it "seems" to be less of vibration, but i can still tell its there. Fuel filter was changed about a couple months ago also, i was gonna check it but it was just a couple months ago, maybe some gunk got loose.
#1fordguy
1997-2006 Expedition & Navigator
05-27-2013 01:24 PM
TheSafeCracker
09-23-2012 12:26 AM
Greg99F250SDPS73
10-31-2008 02:51 PM
Mr Dave73
06-25-2004 03:41 PM
