well im tryin to get my truck perfect runnin condition and i have this viberation between 1700-2100 rpms first gear at like 15-20 mph my last 3 ford trucks did the same thing my explorer and my idi turbo did it now im wondering if the midshaft bearing could be it... i took my back u joint off feels good ?? if any1 has ne ideas let me know oh and the faster you take offf the more noticable it is
When you had the rear u-joint off did you check the drive shaft spline for play? Someone had posted that he had play in the spline and it caused vibration. That would also have been a good time to grease the spline. Remember, the drive line angle changes when you quick start due to axle wrap so the mid-shaft bearing should be checked. The best thing I have done for you is a bump up.
how would i know if my midshaft bearing is bad and yeah my conecter thing is kinda sloppy
Check for play in the bearing by trying to move the shaft up and down and back and forth. Also, if you can feel any flex where the shafts meet in the spline that movement will cause vibration. Your best bet would be to take your truck to a drive line shop. They can check for balance and play.
yeh the midshaft bearing will move up and down pretty easely and the spline will clank from turning the shaft soo what do i gota do? take it apart and just greese it ????
