LPOP upgrade
Old Apr 20, 2008 | 09:18 AM
suprdzlduty's Avatar
suprdzlduty
Question LPOP upgrade
I was doing some work on my 01 350 w 290k and counting and after putting the engine back in had trouble building oil pressure. After several attemps to start and could not get oil pressure decided to change LPOP. At NAPA their replacement oil pump for the 7.3 is a 10 tooth design versus the 14 tooth OEM model, which is for more oil volume, comes with new seal, housing and gasket about a 130.00. I haven't hooked up a oil pressure gauge but the idiot gauge in the truck shows a significant increase. Its not too bad of a job to change while in the truck either. Has anybody else done this upgrade???
Old Apr 20, 2008 | 09:27 AM
Kwikkordead's Avatar
Kwikkordead
Welcome to FTE.
I haven't heard of this, but would like to hear what others have to say about it as well.
Old Apr 20, 2008 | 09:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome here. I would also like to know if there is an advantage to having more psi on the low psi pump.
Old Apr 20, 2008 | 10:49 AM
bigjake0524's Avatar
bigjake0524
Are you going to put a guage on it to see what psi it is now putting out? How long did it take to do this while in the truck?
Old Apr 20, 2008 | 11:42 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
There is only a real problem with a oil pressure issue when you have a dual HPOP setup, where there is two pumps flowing 100% all the time, and the LPOP has trouble keeping the HPO reservoir full (Most add a second line to it)and some get a oil pressure issue when at idle, hot.
Old Apr 20, 2008 | 11:31 PM
jtharvey's Avatar
jtharvey
That sounds very similar in design to the Melling pump that ITP sells, except the Melling is about half that cost. Here's the Melling pump to see if it's similar to the one you have: Low Pressure Oil Pump Was the new replacement the same dept at the stock pump, or were the gears about half as wide/deep?
Also, have you done something to alter your oil pressure gauge? The stock gauge is hooked to a switch, rather than an actual sending unit, and that switch gives an all or nothing signal at 7 psi. I'm curious as to how the dash gauge showed a difference.
Old Apr 21, 2008 | 12:43 AM
orng1's Avatar
orng1
Probably he just saw the oil light turn off faster.
Old Apr 21, 2008 | 11:00 PM
Kwikkordead
This would be a show stopper for me. That would cut the volume of the oil delivered down to about half of what it is supposed to be.
Having a high volume oil pump is good. You can regulate the pressure back down if you have to, (overpumping lifters or blowing out crank seals), but there is nothing you can do about oil starvation from a too-small of an oil pump except put a bigger one back on later on.
If I was in the position to have to rebuild my engine, one of the things on the list is the biggest oil pump that I could find, (within reason.)
Old Apr 21, 2008 | 11:50 PM
jtharvey's Avatar
jtharvey
Dan, from my understanding, Melling's thickness was a specific design reason.
This is a post from Dennis, at another forum:
From the engineer at Melling:
As for the low pressure lube pump, our M208, the pump was re-designed to perform better than the original pump. When we started the M208 pump project we were aware of engine oiling issues and premature wear occurring in the pump. We designed our pump in a way to improve the oil delivery to the engine. But to improve the pump we had to re-design the gerotor unit. The Melling gerotor has a 10 lobed inner versus 14 lobes on the original pump. A 10 lobed inner provides a larger pumping chamber which allowed for a 30% reduction in the thickness of the gerotor set. The reduced thickness eliminated the need for the counter bore on the inner rotor for clearance of the harmonic balancer. The Melling gerotor is symmetrical so no installation issue can occur with the balancer. Even though the Melling pump looks like it will not equal the original it is actually better than the original!
and
Yes, our M208 output is meant to provide the same flow as the original pump but with better oil quality since the gerotor will fill better since it is not as deep as the original.
Edit: More Melling pump info.
In case anyone but me wanted to know, here is the response from Melling (questioning the flow rate of the pump):
Below 2500 rpm the flow rate is as good as or slightly better than a stock pump.
Above 2500 rpm the flow rate is increased over the stock pump.
Above 3500 rpm the flow rate is 10% more than stock.
At test rpm of 700 rpm , 7 gpm
At test rpm of 4000 rpm , 25gpm
Old Apr 22, 2008 | 09:08 AM
Kwikkordead
Well, that just shows that there a lot of people that are much smarter than I am.
I never would have guessed that a thinner pump (shorter gears) would be able to pump more oil.
Makes me wonder why they didn't keep the original height and make a kick a$$ pump.
Old Apr 22, 2008 | 09:17 AM
jtharvey's Avatar
jtharvey
I don't believe it's necessary, really. Brian (BTS) has told me on numerous times that the LPOP produces over double the flow that the engine actually uses as it is now. I never saw less than 50 psi in the block, except at idle when it would drop to 25-30 psi when hot.
Installation issue is the other reason.
"The reduced thickness eliminated the need for the counter bore on the inner rotor for clearance of the harmonic balancer. The Melling gerotor is symmetrical so no installation issue can occur with the balancer. "
jeffrsi
Dec 15, 2016 11:54 PM
sunogbahay
Jun 7, 2016 09:45 AM
jpaitala
Mar 14, 2013 11:20 AM
Perot
Nov 21, 2011 07:02 PM
dieseldrivr
Dec 9, 2009 09:11 PM
