Help!
Old Feb 2, 2002 | 09:15 PM
bigfrank's Avatar
bigfrank
Post Help!
I have an '87 F-250 that I'm doing a top end overhaul on. I found a set of E7TE heads with low milage since rebuilding. I went ahead and bought them because I got them cheaper than it would have cost to re-do mine and thats the casting that should have been there. Now that I got it apart, I find that I have a E4AE block and E5AE heads. Looks like a previous owner swaped out the engine with an '84. From what I can find on the internet, it looks like these heads belong with the block and they have a 67.5 cc combustion chamber. I get conflicting information on the volume of the E7TE heads, depending on where I look. My question is, can anyone tell me for sure what the combustion chamber volume is for E7TE heads, and can I use these heads on my E4AE block without causing problems with the compression ratio.
Thanks a lot,
Frank
ps. Dished pistons.
Old Feb 3, 2002 | 07:37 PM
bigfrank's Avatar
bigfrank
Help!
Just go the whole number off the block. E4AE-6015-FA 22, under that, 6K30. Does the F mean full size car? If the engine is from a car, does that mean it would have a different cam than for a truck application? Do I need to get a different cam now too?
Thanks,
Frank
Old Feb 4, 2002 | 12:32 PM
airharley's Avatar
airharley
Help!
ok on the site I have in my favorites it lists your 351W engine block being used from 80-91. You can look at www.cehighperformance.com to see for your self. Look under the used parts link in the text. Then click on "ford car". Hope this helps some.
Old Feb 4, 2002 | 12:59 PM
Franklin2's Avatar
Franklin2
Help!
I haven't a clue about the numbers thing, but somebody caught me on assuming the casting number corresponded to the year. I guess the casting number is just that, a casting revision that lasted for a long time. And with your heads, if they look close to being the same dimensions as far as chamber size, I wouldn't worry about it. I wouldn't worry about the camshaft either. I doubt you could ever tell the difference, if there is one.
Old Feb 4, 2002 | 08:23 PM
StangMan's Avatar
StangMan
Help!
trozei
40
Sep 12, 2020 09:22 PM
tbirdscott
Sep 15, 2015 11:13 PM
Rusty_Old_F250
Large Truck
Jan 12, 2015 10:30 PM
teched
May 22, 2011 08:13 AM
1966F100FE352
Oct 2, 2008 08:03 PM
