cheap(ish) performance upgrades?
Old Feb 3, 2002 | 11:26 AM
Justin89's Avatar
Justin89
ok, i've finally got some money to spend on my truck and i want a little more power(i want a whole lot but can't afford that) i've got an 89 f-150 bout 200 bucks to spend on an upgrade, i was thinkin like an electric fan and underdrive pulley. maybe a K&N filter(not the FIPK thats too much money) but i want to improve my gas milage and power at the same time, thinkin about bumpin the timming up a little bit too. i already have dual exhaust, no headers, and i'm goin to hollow out my cats. thanks in advance, justin
Old Feb 3, 2002 | 12:54 PM
Hank85713's Avatar
Hank85713
The FIPH is an easy build. I got the filter from the internet (4 wheel parts I think they are on the K&N page as dealers) $65 delivered. Took the snorkels and the filter to a indy mufler shop and they cut me some 3 inch tailpipe and expanded it to fit the 2 items. Went to checkers found a plastic union and bought some 5/8 inch hose. Total cost to build $88. Seems to have really helped, also have a gibson catback exhaust, hypertech chip. You will need to make a mount but I did mine out of some 1/8 stock. Go to the K&N page and look at the installation instructions and you can figure it out.
Be careful with the smaller pulleys as I have read that they limit the effectiveness of the alternator, water pump etc.
Old Feb 3, 2002 | 02:53 PM
restorit's Avatar
restorit
I've heard the same on the underdrive pulleys..... you can run into problems with the alternator not charging at idle, etc. due to too low of an rpm. I would consider the electric fan upgrade. This will give you additional hp (Flex-A-Lite advertised around a 15hp or so gain on a Suburban not too long ago), better fuel economy (1 or 2 MPG), longer water pump life, better cooling in the summer (use a 16"), and quicker warm-up in the winter, assuming you wire in a thermostat that doesn't turn the fan on until the engine reaches a pre-set temperature.
Old Feb 4, 2002 | 07:54 AM
slikness's Avatar
slikness
For electric fans, I recommend getting two 14" PermaCools. That will give you the most cfm for the least amps and will give you better over all radiator coverage than 1 16".
Old Feb 4, 2002 | 08:45 PM
StangMan's Avatar
StangMan
If you do pulleys, don't do the fan. If you do the fan, don't do pulleys. The pulleys will create a minor charging problem at idle with lights/accessories on, but if you have a fan, you'll kill batteries constantly, if not hurt something because you wouldn't be charging above 12V.
Old Feb 4, 2002 | 09:45 PM
slikness's Avatar
slikness
[updated:LAST EDITED ON 04-Feb-02 AT 10:46 PM (EST)]Yeah, you need to do some calculations on your altenator with the pulleys and make sure that your getting enough juice to handle the load. You may need to upgrade to 100 or 140 amps...Just add up your electrical load and see if your altenator can handle it. But make sure you make allowances for the reduced rpms you would get from the pulleys.
Old Feb 4, 2002 | 09:54 PM
79F2504x4's Avatar
79F2504x4
Jarkill
13
Feb 1, 2017 03:23 PM
Justin89
Oct 14, 2008 08:08 PM
73F100*8Mile
15
Jan 18, 2006 04:44 PM
82f1504x4
Offroad & 4x4
51
Dec 12, 2004 07:31 PM
Justin89
20
Jul 7, 2002 11:50 PM
