503.5 HP 351W Stroker
Old Jan 31, 2002 | 04:42 PM
Bull's Avatar
Bull
The new issue of the Car Craft features a build up of 351W stroker putting out 503.5HP so if you are interested in building a stroker motor, check it out!
Old Jan 31, 2002 | 09:51 PM
GendoIkari69's Avatar
GendoIkari69
Don't suppose they have the article on a website?
Old Feb 1, 2002 | 12:19 AM
79F2504x4's Avatar
79F2504x4
The July 2001 issue of muscle mustangs & fast fords has a build up using a 351 and boring and stroking it to a 421. It uses an offset ground 400m cranck and .03 overbore. When it was all said and done it had 537.9hp@6000rpm and 515.3ft lbs@5000rpm. Post back if you want to know more.
Chase
1979 F-250 4x4
71 460 Holley650, MSD OFFROAD, L&L Headers
C6-B&M Transpack
Dana HD44Front/60Rear
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Much more to come
Old Feb 1, 2002 | 09:31 PM
GendoIkari69
Oh I want to know more. I'm looking to really boost the low end torque in a 351W. Want more power in one of my bronco!
Old Feb 4, 2002 | 10:22 AM
UncBob's Avatar
UncBob
Problem is on some of the EFI models of 5.8s I don't think you can do these type of MODS because the engine is SD not MAF
Old Feb 4, 2002 | 08:27 PM
GendoIkari69
Both my broncos are carbed. :-)
Old Feb 4, 2002 | 09:54 PM
79F2504x4's Avatar
79F2504x4
OK sorry about the wait but i was out of town.
They used an custom offset 400M crank, came out to 4.125inch stroke
Bored .030 over
KB hypereutectic pistons to yeild roughly 9.7:1 static comp ratio
Eagle H-Beam rods
Comp Cams XE282 HR Roller Cam 232/240 duration .565/.575 lift
Edelbrock Victor Jr. alum. heads ported and milled
Edelbrock Victor Jr. intake manifold with "turtle" on the plenum floor
Speed Demon 850cfm carb
Underdrive pulleys
ARP bolts
And MSD ignition setup
These are just the basic things listed
Doesnt get to specific on part #s
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
Old Feb 5, 2002 | 12:04 AM
ecarter50's Avatar
ecarter50
Rockaholic
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
May 2, 2012 02:46 PM
fordrules577
Jan 27, 2010 09:23 AM
MER
18
Nov 30, 2008 09:07 AM
Brian460
Jan 7, 2003 11:31 AM
Heywood
Jul 10, 2002 04:14 PM
