Truck Dies When Key Goes From Start To On Position
Ross,I'm pretty sure the diagram showed it in the circuit,but I'll dig it out tonight to verify.I just got back from a parts house that's open late,they matched up my resistor against one their book shows,it matches,so I ordered it.It'll be here in the A.M..My shop manual said to replace if it reads outside of 1.3-1.4 ohms,and mine was reading @ 2 ohms.Hope that was all it was.I'll check in tomorrow after changing it out.Thanks for all the help,everyone.
on
Thanks,everyone.The ballast resistor took care of the problem.I did,however,go through three or four of them at each of two stores,both Echlin and Borg -Warner brands,checking for one within specs(1.3-1.4 ohms).Sad,isn't it?I immediately tried to find the one of their several brands that was made in USA,having a bias in that direction.What I found is that all of them will label where the BOX is manufactured,just not where the part is built.Apparently,they want to overcome the resistance of consumers like myself.
Steve
Steve
