Sponsored by: Real Truck
200 F250 trans issue (electronics)
Old Apr 20, 2008 | 07:50 PM
xcrankshaftx's Avatar
xcrankshaftx
I looking for help.
Brought my F250 to texas, had problems with the trans dropping in and out of overdrive. Brought it to a dealership who changed the solenoid assembly. brought it back to chicago and it did nothing. I'm skiddish after $500 of thanks for nothing... symtoms are as follows
Manually shut off the OD and the trans works fine...sucks the gas though.
Only does it when hot. If we feel it beginning to go in and out of OD ... we can pull off and shut her down for a few. that works usually for a couple hours of drive time back to normal.
If you don not shut it off at all during gas stops etc... makes the problem worse!
It's only and overdrive issue !
any suggestions would help...thanks
Old Apr 20, 2008 | 07:54 PM
high ho silver's Avatar
high ho silver
Were you towing when this happened?
Old Apr 20, 2008 | 08:26 PM
xcrankshaftx
No Towing at all!!
Old Apr 20, 2008 | 09:29 PM
xcrankshaftx
I forgot to mention that No error codes are generated by the problem
Old Apr 28, 2008 | 12:37 PM
xcrankshaftx
?? Looks Like I even stumped the Forum.. I hate when that happens
Old Apr 28, 2008 | 12:58 PM
JJf250's Avatar
JJf250
i have the same problem with my 2001 f250 they are replacing the transmission sometime this week. the truck olny has 25000 miles on it my trans mechanic says that the olny thing that could be done is replace it or compleatly rebuild it
Old Apr 28, 2008 | 04:19 PM
ken kenmnedy's Avatar
ken kenmnedy
Originally Posted by xcrankshaftx
I looking for help.
did you get it flushed lately??? did you change the fluid????
Old Apr 29, 2008 | 08:12 PM
JJf250's Avatar
JJf250
they power flushed mine a few weeks ago and nothing changed on the way back from the dealer the trans started it up again
