Parking brake
Old Sep 21, 2012 | 06:39 PM
Marky48170's Avatar
Marky48170
65 f250, 67 f100, 76 f250
Parking brake
Well I finally got my rear parking brake cables raplaced and also replaced the brake shoes and both work like a charm. Is there a way to rebuild parking brake cables?
Old Sep 21, 2012 | 08:28 PM
P38fighter's Avatar
P38fighter
I'm confused - if you replaced them why do you want to rebuild the old ones?
Having said that I actually did rebuild one. I had a pretty good case but a snapped cable. I measured the cable length and went to a sail rigger and bought the cable and had them crimp on the retainer *****. Worked great - that was 15 years or so ago so prices would be markedly differrent now. Good luck...
Old Sep 21, 2012 | 09:52 PM
Marky48170's Avatar
Marky48170
Just wondering, because I couldn't find the right side locally so I had to pay double the price.
Old Sep 22, 2012 | 02:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965 F250 2WD: There are 4 C5TZ-2A635-B Right Rear Cables available NOS
Old Sep 22, 2012 | 10:33 AM
Marky48170's Avatar
Marky48170
Whats the procedure for adjusting the parking brake after replacing the cables? How much tension should be on the rear cables with out the parking brake on? Or is it just keep adjusting until you get drag on the rear wheels and then back off?
Old Sep 22, 2012 | 05:39 PM
garbz2's Avatar
garbz2
Sort of like this but,
With the drum off adjust the cables until the lever just starts to move the center bar. The lever acts against the centering bar to push each shoe. The cables need a bit of free play as you pull out the handle.
Make make sure you replace the long spring that helps keep the front cable in slight tension.
Garbz
Old Sep 22, 2012 | 06:19 PM
Marky48170's Avatar
Marky48170
Boy I'd hate to have to pull that dana 60 rear end apart again to get at the brakes. Looks like a next weekend project to me. And by the way were is this Long Spring located?
Old Sep 23, 2012 | 07:00 AM
NumberDummy
What is the procedure for adjusting the parking brake after replacing the cables?
Originally Posted by garbz2
Sort of like this but, With the drum off...
Why would you need to remove the brake drum to adjust the parking brake?
1964/66 F100/250 2WD & 4WD:
Front parking brake cable attaches to parking brake equalizer lever located on crossmember.
Parking brake cable adjustment rod attaches to equalizer lever then threads into the equalizer bar that the two rear cables attach to.
Rod has two nuts, one on either side of equalizer bar. Tightning these nuts adjusts all three cables.
Shown here: 1964/72 Ford Truck Parts Catalog / Illustration Section 26 ~ Page 9.
tsevrens
31
Feb 7, 2023 10:14 AM
genscripter
May 22, 2016 10:40 AM
blue924.9
Sep 2, 2015 07:27 PM
bad_habit59
Feb 12, 2009 12:20 PM
MikeGV
Feb 6, 2005 09:43 PM
