replacing door pins and bushing ?
Old Apr 19, 2008 | 04:08 PM
tndiesel's Avatar
tndiesel
I've got everything out and can't seem to get the brass bushings to go into the hole. I'm afraid if I hit them too hard they will break. What is the trick?
Thanks!
Old Apr 19, 2008 | 05:03 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I've never done them on a newer truck but on my old 79 I had to tap them in w/a wood mallet. How tight are they?
Old Apr 19, 2008 | 06:20 PM
tjbeggs's Avatar
tjbeggs
Use a long 1/4 bolt with a nut thru to the other side of the hinge half and snug it up then hit with a hammer. the bolt will stop the spring action of the hinge and the bushing will seat
Old Apr 19, 2008 | 06:55 PM
kawa's Avatar
kawa
Another trick is to grind a slight bevel on the outer edge on the bushing. Presses right in.
Rog
Old Apr 19, 2008 | 08:53 PM
tndiesel's Avatar
tndiesel
Thanks as always guys!
Old Apr 20, 2008 | 11:22 AM
Deesel Dad's Avatar
Deesel Dad
Right on with the bevel grind on the leading edge....after that throw 'em in the freezer for a couple of hours and tap 'em in place while they're still cold. Shouldn't take much to get 'em to drop right in place....
