Sponsored by: Auxito
cracked u joint
Old Apr 19, 2008 | 03:40 PM
40LUTZAG's Avatar
40LUTZAG
Cool cracked u joint
I removed my drive line and noticed that there is a crack on my rear driveline in two spots that hold the u joints what should i do. Do I need a new driveline or what. Its Saturday and no shop is open to press out my u joints and ive never done it. Any suggestions would help. Thank you.
Old Apr 19, 2008 | 03:47 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Exclamation
Are you referring to the yoke part or the driveshaft? Why not call a salvage yard;i'm sure you can find the part/parts there.
Old Apr 19, 2008 | 04:48 PM
sclariat's Avatar
sclariat
if the driveshaft cups are split then you need a new/used driveshaft. don't worry about removing the u-joints from a scrap driveshaft.
Old Apr 19, 2008 | 07:52 PM
mjunk1's Avatar
mjunk1
I can't help you except to say I've been following your u-joint posts for a few days now and you must be extremely frustrated. Why not post a picture of the driveshaft in here so some of the outstanding experts on here can see what you actually mean? A digital camera would sure help out in diagnosing your next step. (Hard to give a harcut over the phone a friend of mine would always say.)
Hang in there!
Old Apr 25, 2008 | 07:33 PM
fireball 440's Avatar
fireball 440
I had the same problem with my '97. It was on the rear flange that bolts up to the diff. It only costs $27 at a Ford dealer (cost). I can't believe how cheap and thin these flanges are made.
Monana ford Man
Aug 19, 2014 01:10 PM
wrdabney
Jul 2, 2011 09:43 AM
40LUTZAG
1997 - 2003 F150
Apr 16, 2008 02:57 PM
BigTony
Bronco II
Jul 1, 2005 02:58 PM
nminer1
Apr 5, 2005 07:25 PM
