Porting my E7's
Old Apr 22, 2008 | 09:49 PM
Hillcapper's Avatar
Hillcapper
Wow Doug, thats some impressive polish work
Old Apr 23, 2008 | 07:11 PM
doug1222556's Avatar
doug1222556
I hope this posts correctly, my borders seem to be screwed up and I can't get them to align, I'm not an idiot, but between a nerd and an idiot,I am probably closer to the latter. If this doesn't post complete sentences, I will try something else.....Thanks for the compliment, I started polishing old war rifles during cancer treatment, and I can tell you, it's kind of addicting. There's something special about turning rusted steel or pitted cast iron into a chrome-like finnish, and one rifle I did still looks perfect without any protection nearly 4 years later. It is very labor intensive to get to that point, but it sure looks awesome, and has to pretty much eliminate hot spots.I know eventually carbon will build up on them. but it has to be reduced in amount and grossly delayed in the time frame it takes to accumulate. Lot o time in those heads.
Old Apr 23, 2008 | 08:29 PM
Hillcapper's Avatar
Hillcapper
I doubt I will have the time to get them to look like yours but what did you use in the final polish stages to get them so smooth?
Old Apr 23, 2008 | 09:21 PM
doug1222556
It's all about going finer and finer with abrasives. The final stages involve 1500-2000 grit sandpaper followed by buffing with jewlers polish, or buffing compounds, depending on how you want to define them. The bulk was done with Mirro buffing compound I bought at Lowe's (the green top for mirror finish) and quite an assortment of cotton and wool buffing pads for a Dremel, and a lot of hand sanding with fine grits beforehand and after (when the polishing highlighted the flaws), untill it looks like chrome. It's something better left to winter nights, when there's not much else to do. If I were to take my time at $5 an hour, I'd probably be money ahead buying some new aluminumn performance heads.
GMCPic
Dec 5, 2013 04:27 PM
Rick_Fury
Nov 4, 2011 06:34 PM
Craig64
Dec 8, 2007 08:14 PM
billybob_81067
Mar 26, 2007 05:11 PM
robertbourque
Mar 18, 2007 02:03 PM
