what size injectors?
Old Apr 19, 2008 | 01:58 AM
kdy72601's Avatar
kdy72601
i have the factory 24lb injectors in my 7.5l and looking to upgrade since my dicovery this weekend. it a '92 f-250 the motor as been bored 30 over ive done exaust, costom cold air intake, and i think my injector are holding me back. so what size injectors should i use.
Old Apr 19, 2008 | 04:52 AM
EPNCSU2006's Avatar
EPNCSU2006
I very seriously doubt that your injectors can't supply the fuel your engine needs. What was your discovery this weekend that made you think you need bigger injectors?
Old Apr 19, 2008 | 09:09 PM
kdy72601's Avatar
kdy72601
well the overbore & pretty the motor is camed and every spark pulge was white ie. lean just like last time i changed them thought was the O2 sensor so i changed that in plugs are still the same lean just like last time so now im thing injectors. do you have any segustion what size to go with?
Old Apr 20, 2008 | 09:11 AM
EPNCSU2006's Avatar
EPNCSU2006
Any idea how much power the engine is making? Have you checked for any codes stored in the computer? Is the fuel pressure up to spec?
Old Apr 20, 2008 | 09:21 PM
kdy72601's Avatar
kdy72601
fuel pressure is good, no problem codes in the computer, im estamiting with desktop dyno about 350hp and right around 500ft. lbs. of tourqe.
Old Apr 20, 2008 | 10:31 PM
EPNCSU2006's Avatar
EPNCSU2006
If you are indeed making 350 horsepower, assuming a BSFC of 0.5, this calculator (Fuel Injector Calculator from WitchHunter Performance) gives a size of approximately 25 lb/hr. The most cost-effective way to increase the fuel flow capacity for your truck would be to get an adjustable fuel pressure regulator and increase the pressure slightly, since the difference between what you have now and what a cheesy online calculator says is quite small. I believe the next size up on Ford Bosch injectors is 30 lb/hr, which would likely be too much for the stock computer to adjust for.
Old Apr 21, 2008 | 05:48 AM
LxMan1's Avatar
LxMan1
You need a chip to lengthen the injector pulse width if you don't have MAF.
Old Apr 21, 2008 | 09:19 AM
Conanski's Avatar
Conanski
You can't just plug in larger injectors, the computer has to be reprogrammed for them. 27lb/hr squirters are what's required to supply 350hp reliably,(80% dutycycle or less), but the 24's can be stretched with a higher fuel pressure as Eric suggested. This is the best option right now since the computer in your truck is not programmable and would have to be changed.
Old Apr 25, 2008 | 07:43 PM
kdy72601's Avatar
kdy72601
ya i know ill need to get a chip i was planing on that any one used the costom chips by motorvation Motorvation Performance Chips Ford Trucks
witch calims to give a 85 horse and 140 ft lbs increase and they costom make the chip to my spec. do i need to catuclate for the 85 horse increse when getting the injectors or will the chip do what it needs to do to make it run right?
Old Apr 26, 2008 | 08:38 AM
LxMan1's Avatar
LxMan1
I would ask the chip maker what injectors that they recommend to go with their tune.
biggdirty7.3
16
Dec 4, 2020 11:15 AM
05 f250 6 inch lift
Mar 31, 2017 05:30 PM
Regulator1988
Jun 1, 2012 10:02 AM
turbill
Dec 22, 2010 06:59 PM
Brown Falcon
May 13, 2010 10:39 AM
