04 Explorer Relay Problem?
Old Apr 17, 2008 | 08:57 PM
ranstl's Avatar
ranstl
When I turn my 04 Explorer (4.0L, XLT, AWD) off - and even remove the key, the windows will continue to work and the radio will continue to play AFTER the doors have been opened, the key fob won't work in any manner, and the doors won't lock or unlock if you press the button on the door. I've also noticed the lights don't come on when in the automatic position, either. I'm taking it to the dealer tomorrow, but was wondering if anyone has experienced this or has any ideas. I've check what I would consider the obvious fuses, and even pulled a few relays. Finally, I disconnected the battery for about an hour.
Any ideas?
Old Apr 18, 2008 | 12:07 PM
87 XLT's Avatar
87 XLT
Sounds like the door switch isnt telling the GEM that you've opened the door.
The switch is in the door latch area, try spraying it with WD-40 and open & close the door to work it in.
If you're lucky this will fix it.
Old Apr 22, 2008 | 09:18 PM
ranstl's Avatar
ranstl
FYI. It was the Security Module. Dealer replaced it under the ESP, and all is well for now.
marshall5610
Jun 9, 2024 04:59 PM
hrspowr
Jan 25, 2021 02:14 PM
JordanL79
Jan 17, 2017 12:44 PM
jistrebe
Jul 19, 2016 12:56 PM
scacho
Electrical Systems/Wiring
Feb 19, 2007 07:22 AM
