No start,no smoke.
Old Apr 16, 2008 | 09:44 PM
d#2's Avatar
d#2
No start,no smoke.
<HR style="COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message --><TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>hello my fellow ford enthusiasts,
96,Econoline,7.3,no start,installed new ford cps & has 5v nothing,checked fuel psi 45, oil psi 3000,all relays&fuses ok,no codes,pull test while cranking,cannot find inertia switch,checked at r kick panel this Eco is a motorhome so maybe its not used.Icp is ok & has 5v ref,Irp at this point can't get at it but with 3000psi at the rail it should fire.
i do not have a scanner that will perform injector solinoid tests.
Is their anyway i can check for power getting to injectors.
any ideas would be great.
ps is their an easy way to check for a bad Idm can a dealer bench chek them.
</TD></TR></TBODY></TABLE>
Old Apr 16, 2008 | 09:47 PM
d#2's Avatar
d#2
No start,no smoke.
o one other thing is their an easy way to check the Idm,or can a dealer benck check them.
Old Apr 16, 2008 | 10:05 PM
tjbeggs's Avatar
tjbeggs
Few questions to check from the start. Does the tach move? does the wait to start light come on? The van has a mechanical fuel pump so no inertia switch. There isn't really an easy way to check the IDM. usually the best way is to replace it with a known good one and see what happens.
Old Apr 17, 2008 | 03:45 AM
Maxium4x4's Avatar
Maxium4x4
Moved to year specific from General diesel
Old Apr 17, 2008 | 08:55 AM
d#2's Avatar
d#2
no start
glow plug system is working,no tach,I will check it with a meter,at multi pin plug.
Old Apr 17, 2008 | 08:56 AM
d#2's Avatar
d#2
sorry no tach in van so i will check it at plug
Old Apr 17, 2008 | 05:31 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Have you tried plugging it in for a couple of hours? Checked the glow plugs and glow plug relay? How about the battery voltage?
What were the circumstances that led to the no start? Had it been sitting for a year, or was it more like "shut it off yesterday, won't start today"?
Edit: Merged crossposted threads.
Old Apr 17, 2008 | 06:27 PM
tjbeggs's Avatar
tjbeggs
Oh yeah forgot the E's didn't have tachs. That is really dumb BTW! Does your scanner have any data you can watch?
Old Apr 17, 2008 | 07:25 PM
d#2's Avatar
d#2
no start no smoke
here is some more of the story,i was backing up, and it shut down not a lack of fuel shut down was an electrical cut out.
the scanner only shows codes,but tomarrow i will have acess to a scanner that has diag func.
Old Apr 17, 2008 | 07:32 PM
tjbeggs's Avatar
tjbeggs
Ok when you get that scanner look at ICP PSI, and IPR duty Cycle. ICP should be a minimum of 420 to start and IPR just report what you see when cranking. Also use the scanner to check for codes. And do a buzz test (injector electronics) if you can. The buzz test will let you in on what the IDM, wiring and injector solenoids are doing
Old Apr 17, 2008 | 08:07 PM
d#2's Avatar
d#2
ok hey thanks for the heads up on what to look for.
Old Apr 18, 2008 | 08:30 PM
tjbeggs's Avatar
tjbeggs
did you get a chance to check it out today?
Old Apr 19, 2008 | 09:31 AM
d#2's Avatar
d#2
yes i got a pro link scanner hooked it up put in all the info like year make engine then scrolled to different functions the scanner comes back with unable to talk with truck. so i hooked up the scanner to three other 250 with 7.3 i get the same responce.
so i went back to the Eco and performed a pin point test on the plug everything is ok with plug.
so the last thing i did yesterday i unpluged the ipr (a real bitch on an eco) pressure went down to a few hundred psi.
i think it is about time to send her to the dealer i don't have a break out box so its tough to do much more at least i think
Old Apr 19, 2008 | 10:15 AM
MADVAN's Avatar
MADVAN
Sounds to be electrical.
Could be a ground issue.
Recheck voltage supply to the IDM and PCM.
Be shure of voltage out on the relays with ign in run and start modes.
In the 96E, the IDM and PCM power is supplied by fuse links. "Load side of relay"
Signal side of relay is fuses.
For the hell of it did you try to start in netural?
Its a 96E. Is it OBD1?
Bill
Old Apr 19, 2008 | 11:03 PM
d#2's Avatar
d#2
i sure did
In the power dist box all fuses are good and hot i swapped the relays around still nothing all fuses under dash are ok and except one it's not blowen but no juice on ethier side maybe it only gets hot during cranking if i introduce 12v on one side it cranks the engine the fuse is #7 for anti theft,trans range,park neutral and PCM???
I did check for refv through the pcm plug useing the grounds in that plug per Fords pin point sheet
I will check main power to the pcm and idm tomorrow
thanks for all the help o ya and GOD BLESS AMERICA
