Mechanical Temp Gauge
Old Apr 16, 2008 | 08:52 PM
89BlackBeauty's Avatar
89BlackBeauty
At the urging of the members here - I am installing a mechanical temp gauge. Finding a spot that is visible to the driver was fun - brake controller, cd player, Pyrometer, etc. But..
How do you install the line through the firewall - drill a hole?? Or is there an existing hole I should be able to use. I need at least a 5/8 hole to get the nut through. Also - what should I fill the hole with - fire caulk, silicon, etc?
Thanks,
89 F-350 Crew Cab, dually, long bed, 7.3 IDI with Hypermax Turbo and 5 spd Tranny.
Old Apr 16, 2008 | 10:31 PM
Breech's Avatar
Breech
If you wind up drilling a hole I'd use a rubber grommet. You should be able to get one from just about any auto parts store.
Old Apr 17, 2008 | 01:01 AM
Happyreefer's Avatar
Happyreefer
I routed all mine through an existing firewall hole. Found it just above the brake pedal.
Pyrometer
Turbo Pressure
Trans Temp
Water Temp
all through same hole
BIGskinny
Aug 20, 2011 05:50 AM
moebdick
Oct 12, 2010 11:45 AM
handyman43358
Dec 4, 2005 09:21 PM
Twin Tritons
Jun 17, 2004 03:19 AM
PatrickMcD
Oct 28, 2003 03:25 PM
