Valve Adjustment (hyd) ...
Old Apr 16, 2008 | 03:00 PM
OldFordRacer's Avatar
OldFordRacer
Is there any reason why I should not adjust 428 Adjustable Rockers the same as I would other engines with adjustable rockers and hydraulic lifters ? ...
I am in the process of installing a New Cam & Lifters with Like-New 428 Adjustable Rockers and Pushrods ...
In the past, I have adjusted FE Rockers by backing off until the lifter fully pumps up and "ticks", then tighten until there is Zero clearance, plus 1/4 - 1/2 turn (the same method used on Chevy V8's) ...
Old Apr 17, 2008 | 01:31 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Depends on the thread-pitch of the adjuster, and how much preload the lifter should have
Sorry, I've only done non-adjustables...
Old Apr 17, 2008 | 03:08 PM
Freightrain's Avatar
Freightrain
Sounds pretty close to me. As long as they aren't ticking then they are preloaded. As long as they aren't bottomed out then you're okay too.
I'd say go with it.
Old Apr 22, 2008 | 12:39 AM
OldFordRacer
Thanks for the info ..... Just returned from another run to Las Vegas and more Hot Rod work with my Son .... I will install the new cam, lifters, rockers and pushrods this week in my 410 and hope to have it purring like a kitten again soon ...
thatguy71
May 27, 2014 08:35 PM
tater_51
Dec 31, 2010 06:45 AM
inliner
Jan 4, 2008 09:01 PM
jstandle
Feb 8, 2005 09:40 AM
ADSf100
Mar 28, 2003 04:59 AM
