Sponsored by: Auxito
u-joint (HOW)
Old Apr 16, 2008 | 02:14 PM
40LUTZAG's Avatar
40LUTZAG
u-joint (HOW)
Hello. I removed the snap rings and the driveline is loose. Now how do you get the u-joints out.
97 4x4 f-150
Old Apr 16, 2008 | 03:13 PM
KingRanchMan02's Avatar
KingRanchMan02
You have to press out the old U-joint and then press in the new one. Get two sockets, one that the bearing cap will slide into and one that will slide through the eye of the joint to push the opposite bearing cap through. Then you will need an arbor press, a vise, or a large C-clamp to do the work of pressing. Push one cap out, then turn it around in the sockets and push the other cap out. Reverse the procedure to press it back in. Be careful to not knock over the needle bearings or you will be doing it again. Besure to mark the pieces that the joint is coming out of so that they are put back together in the same way that they came apart. Good luck!
Old Apr 17, 2008 | 03:17 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
A BFH and a junk (or Craftsman) socket will work too...
Old Apr 17, 2008 | 04:02 PM
KingRanchMan02
That could work for taking the old worn out U-joint out but I wouldn't do it that way and certainly would not use that method to put the new in.
Harbor Freight Tools - Quality Tools at the Lowest Prices
Old Apr 18, 2008 | 12:30 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Why not? My friends and I have been doing that for years and they hold up just fine. Hell...My dad owned a shop for a decade and used (still does) this method to press in wheel bearings, etc... Works just fine.
Old Apr 18, 2008 | 02:30 PM
KingRanchMan02
I am not saying that this method won't work, just that one needs to hit things squarely or risk damage to components. I have always used an arbor press to do this job.
Old Apr 18, 2008 | 05:13 PM
Club Wagon's Avatar
Club Wagon
Using a "BFH" is a crude, yet effective way to R&R U-joints. Trouble is you should never strike bearings you want to use w/hammers. Pressing U-joints in is the safe, reliable & recommended way to do it.
The "Why not? My friends and I have been doing that for years and they hold up just fine. Hell...My dad owned a shop for a decade and used (still does) this method" attitude is often behind many excessively common failures. The traditional brute force "method" was responsible for countless warped brake rotors among those refusing to adopt torque specs for lug nuts.
I strongly suspect that FORD's problem w/blown spark plugs has, at least in part, a lot to do w/the "have been doing that for years" mentality. Mechanics accustomed to tightening the snot out of plugs in iron heads for decades, w/o consequence, did not Climb Onboard when aluminum heads came out. They arrogantly winked at FORD's low torque recommendations.
Old Apr 19, 2008 | 10:24 AM
cstrout28's Avatar
cstrout28
my truck squeaks when im in reverse is that the u-joints? and is replacing them a big deal? like how many hours would they take and how much are the parts?
Old May 5, 2008 | 02:18 PM
kingrat427's Avatar
kingrat427
chances are it is the rear joint , i just did mine today 2 joints on the rear driveshaft, appx 30.00 for h/d ones from napa 1.5 hrs for labor
6.4lfirefighter
Jul 17, 2011 12:53 PM
dantsg
1997 - 2003 F150
Apr 12, 2008 12:21 AM
SDJTO
1983 - 2012 Ranger & B-Series
Feb 5, 2008 08:03 PM
marioc956
Offroad & 4x4
Aug 1, 2007 06:37 PM
MikeFlorida
May 13, 2007 06:52 PM
