Installing a new lift pump
Old Apr 16, 2008 | 12:17 PM
Dieselguy89's Avatar
Dieselguy89
i'm installing a new lift pump in my truck today.
Does anyone have any kinda tips or tricks of installing these pumps.
Or can they just install like a regular gasoline engine fuel pump
Old Apr 16, 2008 | 12:26 PM
PLC7.3's Avatar
PLC7.3
This info pertains to Carter #M60278 pump or new long arm style.
WARNING
This fuel pump must be installed only at the low position of actuator cam.
If the pump is installed at any other position than low cam, the pump will be ruined, the engine will stall and damage may result.
Incorrect installation will loosen the pivot pin and allows the pin and lever to come out of the pump and drop into the oil pan. This can occur immediately or after several hundred miles. This type of failure is not covered by warranty.
To ensure that the cam is at low position, it is necessary to use a mirror and a remote starter switch. Observe the cam through the mounting port and bump the engine around until a one (1) inch wide machine surface is observed. This is low position of the cam. Now complete normal fuel pump installation.
9502CA
1991
Old Apr 16, 2008 | 02:40 PM
shorthair's Avatar
shorthair
I did mine last month & could not see inside with a mirror so I cheated & pulled the gp's & held a screwdriver gently agianst the lobe as the wife turned the crank with a rachet, you can feel where the lobe is .
93f250tn
15
May 26, 2022 09:59 PM
carlfredrickson
16
Mar 31, 2011 04:12 PM
lifted77f250
Jul 26, 2010 06:59 AM
Jayme Duty
22
Apr 4, 2010 05:12 AM
