Anyone every replace their E4OD with an Allison 1000 series transmission? I realize there is a matter of the allison being controlled by a computer but is that seperate from the rest of the GM truck it comes in? I'm sure an adapter plate can be made to mate it to our IDI blocks and new bungs welded onto the Allisons torque converter to bolt it to our flywheel right? What are your thoughts on this guys?
I don't know for sure but I have talked to a few trans. experts that say the Allison 1000 is the best of the "pick-up" trannys but they are far from a "real" Allison. They have all said they are overated.
I have two Allison 545 trans. they are not O.D. equiped but I bought one for $300 and the other for $350. I am going to combine the two (one had all of the Cummins equipment and the other had the "parking" brake and shifter assembly) and put them in my Dodge CrewCab project. I don't need overdrive as I am going to have 36" tires and 3:54 gears. I'm going to run an older Ford divorced NP-205 and '90 Ford Dana 60 frontend.
I'm sure they put these trannys behind IH/Navistar motors too. They all seem to be "universal" with adapters/torque converters to match specific motors. One of mine came out of a Volvo truck. The two I have are in good working order and are completely mechanical. You might look into these trans. if they fit your needs.
I'm sure someone more knowledgeable on auto trannys will chime in on this.
The Allison trans have an there own ECM and you probably could make it work. I drive a Chevy at work that has a newer version of it then the first ones. It had a mode function that let the drive change the gears himself. It will let you red line it if you want.
It is a good trans. They can have problems, like anything else, but they are the most complicated trans Allison ever built as far as electronics is concerned. That means there is more room for error. I was one of the first people in my area to be certified on one at the dealer level in my area. It has been awhile so I can't get very technical about them anymore. I know people that know them very well.
obviously the allison is a unviversal trans , you can buy a flywheel and torque convertor that will bolt up, they did have allisons bolt up to 7.3l engines. and the tcm is way better then the ridiculous pcm's that are in cars, i work at w.w.williams, and i know first hand how much easier they are to work on because the trans practically talks to you, unlike the older AT'S. technology can be great....
I've thought about an allison swap before. I know there are adapters for the engine side. I don't know if one can be converted on the backside to adapt to a Ford transfer case. Might have to go with a divorced unit to make it possible. I have not gotten that deep into the research.
What models and years for these international trucks? I've got a friend that works for a junkyard maybe he get get me one if i knew what they came in. If I got one out of these trucks then all I would need is the flywheel and tranny? What about the crossmember and mount? This is a for a '94 CC Dually 2X4.
You might as well get out the torch,welder, and what ever else you may have. I would say you will be making something to put the trans in your truck. That isn't bad though. I like making things.
I did an E4OD swap, and fitting the new crossmember was easy, just mark the location of the new holes and drill them out (pilot drilling helps). I have no doubt that you can reuse the original crossmember with some minor modding.
I do remember he IDI 7.3 Diesel had a plate on the back of the engine that the trans mounted to, so I would assume it can either be replaced with one that is made for that trans engine combo (assuming there was one ever made), or modified to fit it.
umm international trucks, 4300-4900 series, older obviously, 99 and earlier i think, depends on the size of the truck, city trucks used them, same as the powerstrokes, they were marked as 444t or 444e
