2001 aircooler cleaning?
Old Apr 16, 2008 | 05:31 AM
62trvler's Avatar
62trvler
My truck has 110K miles and I've cleaned the intake tube out once so should i remove the air cooler and clean that also? What would I clean it with? I thought about carb cleaner and sloshing it around then leave outside to evaporate.
Old Apr 16, 2008 | 08:38 AM
Izzy351's Avatar
Izzy351
Have you done the CCV mod to keep it from getting all nasty again? If not, I wouldn't bother until you do. You should just be able to use soap & water (like dish soap to break down the oil), rinse real good, then let dry. I would think that putting it in the sun will dry it out pretty quickly. You could run a leaf blower through it **CAREFULLY** to help speed up the drying process. Just don't run it full blast through there.
