03 explorer 4.6 stalls at stop light
hey guys, I normally spend all my time in the 7.3 forums but I'm now having a problem with my 03 explorer limited 4.6. the engine runs fine at speed but stalls at a stop light or in the middle of a slow turn when the rpms drop the engine just dies. it fires right back up but idles fast for a second and the drops off until it stalls. I pulled the codes with a AE scan tool and it has no codes, I run the engine running scan and it showed the Idle control valve. is this a common problem and what is the fix. Thanks for any info you guys can offer.
mhofmann86
09-22-2015 03:45 AM
