Towing with or without overdrive ?
Old Apr 15, 2008 | 07:36 PM
Phillip Guidry's Avatar
Phillip Guidry
In my 98 F150 owners manual...concerning the towing section...it doesn't state to NOT tow with the overdrive on...it just kinduh" states that it's beneficial to have overdrive off while going up and down steep inclines for engine braking and such...if I tow strictly on flat highway's.....at 1/2 of my trucks payload or tow capacity.......should I worry about the overdrive button ?......the roads I tow on are flat and have a constant change of speed limit between 45 to 55 mph which is right where it want's to shift into 4th gear depending on the gas pedal pressure
Old Apr 15, 2008 | 08:37 PM
grafekie's Avatar
grafekie
This was just discussed, within the last week. Scroll down and read the thread, it had a number of very well written posts.
Old Apr 16, 2008 | 05:27 AM
jowilker's Avatar
jowilker
Phillip, The general consensus is as long as it is not hunting or changing in and out often, you are ok to use OD.
John
Old Apr 16, 2008 | 06:20 AM
Phillip Guidry
Thanks for the replies !!!!
amyr61
Aug 7, 2011 05:32 PM
joelswork
Sep 16, 2010 04:18 PM
F-350 in Buckhead
Aug 24, 2010 05:28 AM
NXGTS
Modular V10 (6.8l)
May 8, 2009 03:32 PM
stecz
Aug 9, 2003 03:20 PM
