Sponsored by: Real Truck
Brake problem
Old Apr 15, 2008 | 02:38 PM
stroken's Avatar
stroken
Brake problem
When I apply my brakes my truck like jumps it feels like.....I am putting on my new wheels and tires tomorrow and have new brake pads to put on both the front and back..should I replace the rotors also? What do you think is causing this? I do have a lifted truck on 37's with out having slotted rotor and I have bendix pads....any ideas?
Old Apr 15, 2008 | 02:58 PM
radio flyer's Avatar
radio flyer
Cut rotors, or replace if they are too thin.
Old Apr 15, 2008 | 03:00 PM
mhoefer's Avatar
mhoefer
You need to inspect the rotors and pads and replace if minimum thickness is not present. At a minimum, rotors need to be turned for new pads.. Turning rotors can improve braking but in the heavy SD can also increase likelyhood of warping once they are to thinner. Some recomend just going to new rotors. I would say with 37's and the issues you have, new rotors and pads are best, I would go with Cryo and Hawk pads if you dont want to do this on a regular basis. 2003 are notorious for this... The 2005 and up have slightly bigger rotors and this improved.
Old Apr 15, 2008 | 03:05 PM
stroken's Avatar
stroken
the rotors have been turned once, about a year ago...buy new?
Old Apr 15, 2008 | 03:09 PM
03_PSD's Avatar
03_PSD
your rotors might be warped
Old Apr 15, 2008 | 03:10 PM
stroken's Avatar
stroken
seems like it gets worse as the brakes get hotter....when I first leave the house they are fine, after using them a few times is when my problems start....
Old Apr 15, 2008 | 03:11 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, you probably will have to buy new, but a brake shop will be able to tell you if the existing rotors can be reused.
For me, I almost never have rotors resurfaced. They get thinner and are easier to warp. I think it is more economical in the long run to replace the rotors instead of turning them down. I will only turn a set of rotors if I know I will be selling the vehicle within 3 or so months.
Old Apr 15, 2008 | 03:13 PM
03_PSD's Avatar
03_PSD
wonder if you got sticky slide pins on your calipers
Old Apr 15, 2008 | 03:16 PM
stroken's Avatar
stroken
my buddy is a manager at advance auto....he is getting me prices on new ones now! thanks guys!
Old Apr 15, 2008 | 03:17 PM
03_PSD's Avatar
03_PSD
keep us up to date on what you figure out Kenny
Old Apr 15, 2008 | 03:52 PM
stroken's Avatar
stroken
Well I got another question, after i asked my buddy to get me prices, he ran into a bunch of options.....antilock brakes. monobeams and all of ths crap..how do I find all of that out? or if anyone would have a clue...,my truck is in my sig if that discription will help anything....
Old Apr 15, 2008 | 05:23 PM
stroken's Avatar
stroken
Can you measure the thinkness of the rotors? if so what are they supose to measure?
Old Apr 15, 2008 | 06:09 PM
radio flyer
Machine shop that will cut them will have the specs.
Old Apr 15, 2008 | 06:23 PM
stroken's Avatar
stroken
Okay, i was just curious to weathewr have them cut down or buy the new ones tonight....
Old Apr 15, 2008 | 07:30 PM
redford's Avatar
redford
Yes, you have antilock brakes.
