fuel tank switch?
Old Sep 27, 2009 | 03:13 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You have a 3 port selector valve on the frame rail driver side.
You got to test the wiring and selector valve.
Unplug the selector valve and hook a test lamp in line with ground to it's wire.
Turn the key to run, and flip the selector switch on the dash. The test light should be on for one tank, but not the other. If neither tank selection lights the light, you have bad wiring or selector switch in dash.
If the test light lights on one tank but not the other, the wiring and selector switch is functioning. The problem is with the selector valve and/or ground.
Old Oct 3, 2009 | 06:54 PM
texasblues's Avatar
texasblues
Hello...i'm having the same situation on mine....same truck 1984. Nice. Picked it up last week from an uncle of mine. It's been sittin' up for 2 years. Ran fine when he parked it. Can't get it to register fuel & somebody please tell me where in blazes is the tank switch? I'm not real smart but i've crawled all over this thing & the mystery continues....help!
Thanks, texasblues.
Old Oct 4, 2009 | 08:36 AM
ctubutis's Avatar
ctubutis
On the RH side of the heat/defrost/AC control panel.
Old Oct 11, 2009 | 12:02 AM
chubbs222's Avatar
chubbs222
thanks for saying that it helped me
Old Oct 11, 2009 | 12:05 AM
chubbs222's Avatar
chubbs222
try pouring alittle gas in the carberater that pump the gas and start it. and make sure there is gas in the gas tank.
Old Jul 31, 2017 | 03:48 PM
duphofff's Avatar
duphofff
> > Some of the aftermarket suppliers (like the outfit in Kansas) are buying fuel senders from Ford and listing them in their catalogs.
Just read this old thread while attempting to solve a fuel issue.
Bill, a question for you...
Now, is that the same place in Kansas that sells crummy Chinese made rubber products instead of quality ones made by Dennis Carpenter here in the USA? I guess you have to pay for the commercials on Velocity some how.
Old Jul 31, 2017 | 05:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Now, is that LMC truck in Lenexa Kansas that sells crummy Chinese made rubber products instead of quality ones made by Dennis Carpenter here in the USA?
fp_5
Oct 24, 2021 12:07 AM
Zia-Lycan
Large Truck
Nov 8, 2017 11:29 PM
lovethetrucks
Jun 27, 2017 07:13 PM
Lee bias
Dec 29, 2016 10:40 PM
Festeraeb
Feb 29, 2016 03:28 PM
