1995 F350 7.5L Extending Range (125 gallon Semi tank)
It appears the fuel pump went out on my front tank and now that I am making trips across country hauling horses I thought it might be time to upgrade the fuel capacity so i can pass a gas station or 2. I have a crew cab with a 2 foot gap before my Flatbed starts that I had mounted a tool box. I am thinking of putting in a 125 gallon tank from a Semi. Has anyone done this? I plan on leaving the Rear Tank Intact as a back up as I dont think I will be able to get an acurate fuel sending unit. So if I run out I will have the rear tank in reserve. My plan is to mount the tank with a universal 45 psi inline pump that is activated when the fuel selector switch in the truck is switched to the front tank. Does anyone know what issues I might run into or have any suggestions? I have seen it done on diesel not gassers and was wondering why.
You need more than a 45 PSI supply pressure. The regulator on the fuel rail sets the pressure at the injectors. You will also need a shut-off valve to the add-on tank when trying to run the rear tank. In a factory dual tank system each Fuel Delivery Module has a valve inside to prevent the running pump from back flowing into the powered off pump.
Received 3,090 Likes
on
That might work I just figured since I had to replace the fuel pump I might as well just straight plum the new tank. I could just drop the existing tank replace the pump and hook the auxiliary tank upmtomthe filler and use a small low velocity transfer pump to fill the tank as I go down the road.
http://www.ebay.com/itm/NEW-FUEL-PUMP-MODULE-WITH-INSTALLATION-KIT-STRAINER-FORD-VEHICLES-GA1200MN-/380991680419?fits=Year%3A1995%7CMake%3AFord%7CMode l%3AF-350&hash=item58b4dfafa3:g:Rg0AAMXQxU5SAqgM&vxp=mtr has anyone tried one of these. Seems like a pretty cheap price. Kinda thinking of the switch to transfer fuel route.
HRTKD
Toy Hauler Towing; Fifth Wheel & Bumper Pull
21
10-14-2017 10:46 AM
1996 F350 Dually CC
12-13-2013 01:52 PM
nel
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-06-2005 07:23 AM
