4V Versus 2V - 400M
So that gets me to wondering about application.
I only use this truck for hauling a camper around, and my gooseneck dump trailer. I'm not interested in going 100 mph, but need best MPG I can get, and good power to get up and go when its time to. I currently have an Edlebrock intake and Holley 650CFM installed. Should I swap out the 4V setup for a 2V?
It was not available on the cars with 351M's (1975/79) or 400's (1971/79) either.
351M/400 = 2V carbs only (that also includes 1978/82 Bronco's and 1980/82 Econolines).
Good luck!
Also, there have been some rare trucks asked about on here.. special fleet options and whatnot, couldn't they have made intakes for large special orders? or possibly a 4v option they were toying with near the engines end of life that never really hit the gruond (or brochures)
sucks there wasn't internet (as we know it) in the 1970s
Good luck!
NONE list a 4V intake manifold or a 4V carb for a 400.
The Muscle Parts Catalogs don't show a 4V 400 intake manifold, either.
What is the Ford casting number shown on this supposed 400 4V intake manifold.
What is the Ford ID engineering number from that EGR spacer plate?
The spacer plate upper/lower gaskets also have Ford ID numbers on them.
1965/72 & 1973/79 Ford Passenger Car Parts Catalogs / Section 93 / 9433-Gasket Set, Intake Manifold.
D0AZ-9433-B .. Intake Manifold Gasket Set / Fits: 1970/74 351C 2V.
D0AZ-9433-A .. Intake Manifold Gasket Set / Fits 1970/74 351C 4V.
D1AZ-9433-A .. Intake Manifold Gasket Set / Fits: 1971/74 400 2V.
Where's the intake gasket set for a 400 4V? You won't find one because none exists.
The large secondaries on the EGR plate are exactly the same as used on 1973/74 351C 4V's
The intake manifold looks exactly like the one used on 351C 4V's.
351C, 351M and 400 engines all look identical.
Both have the 8 bolt valve covers, no timing cover, and the fuel pump mounting bolts at 12 and 6 o'clock.
Look around...anywhere, see if you can find a FoMoCo VIN engine code for a 400 4V. You can't because there isn't one.
1973/74: H = 351C 2V / Q = 351C 4V / S = 400 2V. That's it.
I was a Ford partsman for 35 years, so I'm not someone who thinks a 400 4V manifold exists, just because they saw one advertised on ebay!
THERE'S NO SUCH THING!
