Since I got my DP-Tuner this weekend I figured I needed to get more air into the truck, yes the 6637 works great but with all this new power I needed to get better airflow. I present the WhosyerGenedad- Wicked Wheel, not sure how much it will lower your EGTs but I am sure it gives a good 5 pounds of booosht!
Yes folks, during Justin's WW install, we pulled his CAC tubes and manifold off just to make room and have a look. What an oily mess from the CCV still in factory config. What do we find in the cold side pipe? This means some PO was a complete moron.
Now clean out them pipes and boots, and do that CCV mod Justin.
It is set for this weekend Mike, you have no worries there . But we also found out some good news, I got a fairly new HPOP and a new up-pipes. Mike you know this set up right here has to add a couple of Horshpower
