Sponsored by: Auxito
tire inflation
Old Sep 5, 2001 | 09:10 PM
Torky's Avatar
Torky
tire inflation
Old Sep 27, 2001 | 06:27 PM
forddy's Avatar
forddy
tire inflation
what is the correct tire pressure for a set of goodyear 24575r16s? I currently have them inflated to 42psi front and back.
Old Sep 27, 2001 | 09:13 PM
Ultramagdan's Avatar
Ultramagdan
tire inflation
Depends on the tire. Check your sidewall for max inflation amounts. If you do all highway, you could knock some pounds out and get a better ride and avoid wearing the center of the tire out.
But some tires perform better at full psi (Goodyear Regattas II) while others do better if you operate them 2-10 lbs under. Check with your tire dealer for the best poundage in your tire for your truck.
Just don't under inflate them and cause the sidewalls to build up excessive heat.
98 F250LD 4X4
Slotted Rotors
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
