Cps ----- Not?
Old Apr 14, 2008 | 12:09 AM
mkmathis76's Avatar
mkmathis76
Cps ----- Not?
I have a 2002 7.3L Turbo with 65,000 miles and recently when I drive it for awhile it will just die. After I let it sit for approxiamtely 30 minutes it will start up again and run for who knows how long. It does not seem to be affected by cold, hot, rain, or dry. It has died on me in all situations, and sometimes it will happen within a mile or two and then other times it will drive 20+... CPS has been changed and but it still died....
Please give me some ideas..
Old Apr 14, 2008 | 06:25 AM
F350-6's Avatar
F350-6
Where did you get your CPS from? Some after market ones have been known to fail right out of the box. There's also been a few problems reported with some of the new ones from Ford involved in the recall.
Do you get a SES light that stays on when the truck is running? Are there any other symptoms you can share with us?
Old Apr 14, 2008 | 08:57 AM
1996pwrstrk's Avatar
1996pwrstrk
When it dies is it like you turned the key off or is it like it ran out of fuel ?
Old Apr 14, 2008 | 09:19 AM
mkmathis76's Avatar
mkmathis76
Talking
The shop supplied the sensor...So I do not know yet....
I do not receive any "idiot" lights at all. It just truns off whenever it decides too. THe first time it started doing it was when I was driving in <30 degree weather and about 2.5 feet of snow. And coincidentally my steering pump went out due to the extreme "wheeling".....I did not have a clue at this time except that I might have got snow into the airbox or something... So the next morning I drove about 30 miles home and thought nothing of it.
The second time it happened I thought it ran out of diesel due to the fuel level the wife had left it at. And after a good 30 minutes of sitting (before receiving the fuel) it decided to start without hesitation. I thought it was odd that it would start so quickly "after running out of fuel" but I went ahead on my way when after a couple miles it did it again and again totalling 3 times in a 10 mile drive. Everytime it would need to sit for approximately 30 minutes. This evening was also cold and wet...
The last time it was warm and dry and would only go a mile or two when it would die... I got it to the shop and replaced the sensor and steering pump and thought all was good when after driving home it started happening again. Only this time it stalled at a stop sign and then almost immediately restarted(which was a first). So I decided to go drive for awhile and you know what I am going to say next.......$@*!&$@!!!
I have driven this truck about 4500 miles in the last 21 months..And the only work I have ever done in the last 4 years of owning it is change the oil, clean the aftermarket air filter, steering pump x2, and a pittman arm.. THe only other issue I have had is when pulling a load in extreme cold it seems to be starving for air or something... I can usually hear a winding up and a "pressure release" when I let off the throttle but in the 20's or colder it will not "release" and it seems to be lacking of power a touch...
Sorry for the novel but this my entire story involving the truck and hopefully it will help..Thanks to all in advance for any help provided.
2002 F250 Lariat 7.3L Turbo QuadCab Long Bed 4x4, 6" lift, 36" Super Swampers-TSL Mud Boggers, K&N style air filter,
Old Apr 14, 2008 | 09:20 AM
mkmathis76's Avatar
mkmathis76
It is like the key was turned off......
Old Apr 14, 2008 | 09:37 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Go to your local ford dealer and get a new Gray CPS for around 27.00 and put it in. Drive around and see if that is the problem. If not you will have a spare.
Let us know.
Old Apr 14, 2008 | 09:45 AM
F350-6's Avatar
F350-6
Do all your dash lights / gauges function normally when you have this no start condition? Does the glow plug light come on and go off like normal? Does the water in fuel light ever flash? Does the tach move while trying to crank (during no start)?
A spare CPS is not a bad idea.
Old Apr 14, 2008 | 12:14 PM
chrissknr's Avatar
chrissknr
I had a similair situation in that i had intermittent problems with the engine stalling and lossing all power, i pulled the DTCs which read a CPS failure, i then replaced the CPS with an expensive CPS from napa thinking id get what i paid for. The truck still missed and stalled and then i recieved the recall notice from ford and took the truck in . . . since then ive had no issues and no DTCs. turns out the CPS that the stores currently carry are simply the same factory replacement CPSs that ford has recalled, ford apparently has a better model which is provided under the recall. Give that a try
Old Apr 14, 2008 | 12:19 PM
mkmathis76's Avatar
mkmathis76
All dash lights are normal.....And my mechanic said that the CPS came directly from Ford.
Old Apr 14, 2008 | 12:29 PM
mkmathis76's Avatar
mkmathis76
Crank vs. Cam
Is there actually a crankshaft sensor and a camshaft sensor?
Old Apr 14, 2008 | 12:41 PM
miller_feed
Same thing. Any sensor you buy for whatever reason could be bad right out of the box.
Did you do the recall? If not bring it to any dealer and 20 mins, no charge you will have a new CPS installed.
Old Apr 14, 2008 | 12:57 PM
mkmathis76's Avatar
mkmathis76
Yes, but I am wondering if he could have changed the cranshaft sensor instead of the camshaft sensor....I could understand a mistake like that if so...lol
<TABLE style="BORDER-RIGHT: #1a3658 1px solid; BORDER-TOP: #1a3658 1px solid; BORDER-LEFT: #1a3658 1px solid; BORDER-BOTTOM: #1a3658 1px solid" cellSpacing=0 cellPadding=3 width="100%" border=0><FORM name=updateQuantity onsubmit="return _CF_checkupdateQuantity(this)" action=index.cfm?action=updateQuantity&orderitemco unt=2&siteid=214290 method=post><TBODY><TR><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=left width="100%">Description</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>Qty</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>MSRP Price</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>Your Price</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle> </TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>Core Price</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>Total Cost</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle> </TD></TR><TR><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" align=left>Mechanical Catalog - Ford
Crankshaft position sensor, f250 pick-up - 1999-07 super duty </TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right><INPUT class=textbox id=qty1 maxLength=4 size=2 value=1 name=qty1></TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$48.98</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$25.96</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right> </TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$0.00</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$25.96 </TD><INPUT type=hidden value=9426878 name=orderitemid1> <TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=middle> </TD></TR><TR><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" align=left>Mechanical Catalog - Ford
Camshaft position sensor, f250 pick-up, 7.3l diesel - 1999-07 super duty </TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right><INPUT class=textbox id=qty2 maxLength=4 size=2 value=1 name=qty2></TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$190.93</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$101.21</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right> </TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$0.00</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$101.21 </TD><INPUT type=hidden value=9426890 name=orderitemid2> </TR></TBODY></FORM></TABLE>
Old Apr 14, 2008 | 01:02 PM
miller_feed
<TABLE style="BORDER-RIGHT: #1a3658 1px solid; BORDER-TOP: #1a3658 1px solid; BORDER-LEFT: #1a3658 1px solid; BORDER-BOTTOM: #1a3658 1px solid" cellSpacing=0 cellPadding=3 width="100%" border=0><FORM name=updateQuantity onsubmit="return _CF_checkupdateQuantity(this)" action=index.cfm?action=updateQuantity&orderitemco unt=2&siteid=214290 method=post><TBODY><TR><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=left width="100%">Description</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>Qty</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>MSRP Price</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>Your Price</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle></TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>Core Price</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle>Total Cost</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top noWrap align=middle></TD></TR><TR><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" align=left>Mechanical Catalog - Ford
</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right><INPUT class=textbox id=qty1 maxLength=4 size=2 value=1 name=qty1></TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$48.98</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$25.96</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right></TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$0.00</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$25.96 </TD><INPUT type=hidden value=9426878 name=orderitemid1> <TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=middle> </TD></TR><TR><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" align=left>Mechanical Catalog - Ford
</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right><INPUT class=textbox id=qty2 maxLength=4 size=2 value=1 name=qty2></TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$190.93</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$101.21</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right></TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$0.00</TD><TD class=tableText style="BORDER-BOTTOM: #1a3658 3px double" vAlign=top align=right>$101.21 </TD><INPUT type=hidden value=9426890 name=orderitemid2> </TR></TBODY></FORM></TABLE>
Is the Crankshaft for the Diesel or gas engine? The CPS says 7.3 in the discription.
Old Apr 14, 2008 | 02:35 PM
mkmathis76's Avatar
mkmathis76
Well, I found out the codes....
PO381
PO1209
PO1212
PO340
PO1211
PO670
We reset them and are at a stand still... Anyone have suggestions as to where to look next with all these codes?
Thanks guys for all your help!!!
barkmulcher
23
Sep 2, 2011 01:14 PM
ftowelding
Dec 9, 2010 11:57 PM
aczar
18
Oct 22, 2009 07:53 AM
Poohbear
39
Oct 17, 2007 05:43 PM
rhodester
17
May 7, 2006 05:27 PM
